Lenovo G25-20 24.5" FHD 165Hz 0.8ms Gaming Monitor
Quicklinx: GWXFWS00 Mfr#: 66D6GAC2UK
Experience the thrill of intense E-sports games on the uber-cool Lenovo G25-20 monitor. With its 24.5-inch screen, the ideal size for gaming, the G25-20 ensures all the breathtaking action happens right in front of you. An ultra-fast 1ms GtG response time with up to 0.8ms MPRT, and an impressive refresh rate of 165 Hz go hand in hand with AMD FreeSync Premium technology to ensure smooth, consistent display with no lags, motion blur, tearing, or stuttering. High Dynamic Range (HDR) decoding with 400-nit brightness allows for incredible lifelike colors and sharp contrasts, letting you smoothly maneuver lightning-fast games. While you are at it, the exclusive Lenovo Artery software offers special gaming functions that let you swiftly optimize display settings to cut through competition in the nick of time.
Lenovo G25-20 - LED monitor - Full HD (1080p) - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class E
Adaptive-Sync Technology
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch
0.2832 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
0.8ms (MPRT), 1ms (level4, 2ms (level3), 3ms (level2), 4ms (level1), 5ms (off)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
55.75 cm x 23.48 cm x 36.78 cm
5.5 kg
English / United Kingdom
CCC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
25"
Viewable Size
24.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2832 mm
Pixel Per Inch
90
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 8-bit Colour Depth, 3-side NearEdgeless, HDR decoding
Raven black
55.75 cm x 23.48 cm x 36.78 cm - with stand
5.5 kg
2 x HDMI , DisplayPort , Audio line-out
Mechanical
Height, tilt
Tilt Angle
-5/+22
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
17.8 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption (Max)
27 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Lenovo Artery, Lenovo Display Control Center
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand (lowest position) - width: 55.75 cm - depth: 23.48 cm - height: 36.78 cm - weight: 5.5 kg , With stand (highest position) - width: 55.75 cm - depth: 23.48 cm - height: 49.78 cm - weight: 5.5 kg , Without stand - width: 55.75 cm - depth: 4.93 cm - height: 33.35 cm
Shipping Width
40.5 cm
Shipping Depth
62 cm
Shipping Height
18.6 cm
Shipping Weight
6.8 kg
Limited warranty - 3 years
