The Lenovo Essential Wired Combo keeps things uncomplicated. This durable keyboard and mouse plugs into any USB port with wired reliability you can count on. The tough waterproof membrane can handle accidental spills without risking performance. Enjoy feel-good typing with quiet keys and number pad in a modern space saving layout. An ergonomic full-size mouse offers comfort and support for all-day use. Increase your productivity as you smoothly complete tasks with the 1000dpi high resolution optical sensor.
Tenaciously stylish
A rugged set that not only passed rigorous performance tests, but passed them all while still looking sleek and stylish. -
A fluid typing experience
Island style keys and quiet key strokes give you a typing experience like no other- and it's all liquid resistant! -
Frictionless control
A high-resolution, 1600 dpi optical sensor ensures you'll be smoothly gliding from window-to-window.
- Lenovo Essential Wired Combo - keyboard and mouse set - UK Input Device
- Keyboard and mouse set
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Function
- Mute, play/pause, backward, forward, volume -, volume +
- Protection
- Spill-resistant
- Pointing Device
- Mouse - wired - optical
- 1-year warranty
- Interface
- USB
- Dimensions (WxDxH) / Weight
- Keyboard: 42.4 cm x 14.64 cm x 2.02 cm / 570 g , Mouse: 6.32 cm x 11.13 cm x 3.37 cm / 69 g
- Hot Keys Function
- UK
- Adjustable Height
- Protection
- Spill-resistant
Pointing Device
- Mouse - wired
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 dpi
- UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KCC, EAC, AAA
- OS Required
- Microsoft Windows XP/ 7 / 8 / 8.1 / 10
- Limited warranty - replacement - 1 year
- 0 °C
- 50 °C
- 10 - 90%
