Robust, practical and affordable: that's the Lenovo E31-70. Perfect for business users looking for an entry-level notebook, the E31-70 proves that you don't need to sacrifice value-for-money for performance.
This Lenovo notebook is equipped with an Intel i3 processor, 4GB RAM and a 500GB hybrid drive. Its thin and light design - weighing in at only 1.59kg - means it's easily portable, while its battery life of up to five hours gives you time to get those essential tasks done while you're on the move.
The E31-70 also features a flexible 180-degree hinge - ideal for easy screen sharing - as well as an integrated webcam, microphone and stereo speakers. Its razor-sharp display provides stunning visuals and its array of apps mean you can stay productive and connected.
Lenovo's AccuType keyboard provides an easy and intuitive feel when you're typing, and you can also rely on its security features to keep your sensitive information safe.
- Lenovo E31-70 - 13.3" - Intel Core i3 - 5005U - 4 GB RAM - 500 GB Hybrid Drive - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L
- Storage
- 500 GB Hybrid Drive (8 GB flash) / 5400 rpm
- Display
- 13.3" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, 10/100 Ethernet
- Battery
- 2-cell - up to 5 hours
- Security
- Fingerprint reader
- Black
- 32.3 cm x 23 cm x 2.15 cm
- 1.59 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5005U / 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 500 GB Hybrid Drive SATA 6Gb/s (8 GB flash) / 5400 rpm
Display
- 13.3" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3160
- Network Interface
- 10/100 Ethernet
- Technology
- 2-cell
- Capacity
- 35 Wh
- Run Time
- Up to 5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , VGA , HDMI , Headphone/microphone combo jack , LAN
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Office 2013 (Trial)
- Black
- Security
- Included Accessories
- Power adapter
- Localization
- 1.59 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- 0 °C
- 40 °C
- 10 - 90%
