Keep your x230T or x220T system powered for longer with the 6-cell ThinkPad Battery 67+. Compatible with the X220T and X230T systems, this battery can be used as a replacement or as a convenient spare for additional power on the go. On average, the battery lasts for 66 watt hours and can be recharged. The Lithium-Ion technology ensures a safe flow of power and each battery is safeguarded against damage from incorrect voltage with over-discharge protection. However, it is not compatible with the ThinkPad External Battery Charger (40Y7625).
*Battery life is affected by a range of factors. These include: battery conditioning, power management, applications, screen brightness, features and other customer preferences.
- Lenovo ThinkPad Battery 67+ - laptop battery - Li-Ion - 66.6 Wh
- Laptop battery
- 387 g
- Battery
- Lithium Ion 6-cell - 66.6 Wh
- 23.8 cm x 9.934 cm x 2.745 cm
- 1-year warranty
- Designed For
- ThinkPad X220 Tablet 4294, 4296, 4297, 4298, 4299, 4300, 4301; X220i Tablet 4294; X230 Tablet 3434, 3435, 3437, 3438; X230i Tablet 3434, 3435
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 11.1 V
- Capacity
- 66.6 Wh
- UL, C-Tick, cUL, PSE Mark, ACA, KC
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 8 - 95%
- 23.8 cm
- 9.934 cm
- 2.745 cm
- 387 g
- Designed For
- Lenovo ThinkPad X220 Tablet 4294, 4296, 4297, 4298, 4299, 4300, 4301 , Lenovo ThinkPad X220i Tablet 4294 , Lenovo ThinkPad X230 Tablet 3434, 3435, 3437, 3438 , Lenovo ThinkPad X230i Tablet 3434, 3435
