With its I5-5200U processor, the Lenovo Core i5 packs a powerful punch, helping you boost your productivity whether you’re at the office or on the go. Weighing just over 2kg, it’s ideally lightweight to carry around in your bag – so you can enjoy both work and play wherever you’re based.
Enjoy superior visuals on account of the Lenovo i5’s 15.6-inch HD display with LED backlight, as well as the Intel HD Graphics 5500. It also comes with anti-glare to protect your eyes every time you’re working.
With an integrated webcam, microphone and stereo speakers, make the most of clear audio – whether you’re immersed in a game, watching your favourite film, or video-calling your family.
Access the internet on the go using the 802.11n wireless technology and take advantage of super-speedy and uninterrupted browsing, even when you’re on the train.
Take full control over access to your Lenovo notebook using the advanced security features, allowing you to set up an administrator, hard drive and power-on password.
BT Shop partners with trusted manufacturers like Lenovo to bring you laptops of the highest quality for the best price.
Thin and light
Thinner than 1" and small starting weight, it is easy to carry around. -
Great performance
Enjoy the power of the efficient processor, discrete graphics and more. -
15.6" widescreen display
The display delivers bright, crisp visuals in HD resolution. -
Enhanced graphics
With advanced graphics technology, you'll enjoy stunning visuals. -
Fast data transfer
Move data between the B50 and other devices quickly with USB 3.0. -
HDMI output
Easily connect to your TV or monitor for large-screen high-definition viewing. -
Swift connectivity
With 802.11 b/g/n Wi-Fi connectivity and Bluetooth 4.0, you'll be able to connect to the Internet wherever you go. -
Integrated webcam
The webcam helps to make your web conferences or online video chats a breeze.
- Lenovo B50-50 - 15.6" - Intel Core i5 - 5200U - 4 GB RAM - 500 GB Hybrid Drive - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB Hybrid Drive (8 GB flash) / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- 4-cell - up to 4 hours
- 37.8 cm x 26.5 cm x 2.29 cm
- 2.3 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB Hybrid Drive SATA 6Gb/s (8 GB flash) / 5400 rpm
- Optical Drive
- DVD-Writer
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 32 Wh
- Run Time
- Up to 4 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password
- Included Accessories
- Power adapter
- Localization
- 2.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- 0 °C
- 40 °C
- 10 - 90%
