Lenovo B50-50 i5-5200U 4GB 500GB + 8GB SSHD 15.6" DVDRW Windows 10
Quicklinx: C2WRWS00 Mfr#: 80S2000LUK
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
Intel Broadwell ULT processor
B50-50 is powered by Intel's new mobile processor – the Intel Broadwell ULT. This processor uses less power than the BayTrail T (far-left column) and allows Lenovo to aggressively attack the entry-level Windows OS tablet segment.
  • Thin and light
    Thinner than 1" and small starting weight, it is easy to carry around.
  • Great performance
    Enjoy the power of the efficient processor, discrete graphics and more.
  • 15.6" widescreen display
    The display delivers bright, crisp visuals in HD resolution.
  • Enhanced graphics
    With advanced graphics technology, you'll enjoy stunning visuals.
  • Fast data transfer
    Move data between the B50 and other devices quickly with USB 3.0.
  • HDMI output
    Easily connect to your TV or monitor for large-screen high-definition viewing.
  • Swift connectivity
    With 802.11 b/g/n Wi-Fi connectivity and Bluetooth 4.0, you'll be able to connect to the Internet wherever you go.
  • Integrated webcam
    The webcam helps to make your web conferences or online video chats a breeze.
Lenovo B50-50 - 15.6" - Intel Core i5 - 5200U - 4 GB RAM - 500 GB Hybrid Drive - UK
Notebook
Operating System
Win 10 Home 64-bit - English
Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB Hybrid Drive (8 GB flash) / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Keyboard
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
4-cell - up to 4 hours
37.8 cm x 26.5 cm x 2.29 cm
2.3 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5200U / 2.2 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller, Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
500 GB Hybrid Drive SATA 6Gb/s (8 GB flash) / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Network Interface
10/100 Ethernet
4-cell Lithium Ion
32 Wh
Run Time
Up to 4 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password
Power adapter
Localization
2.3 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
10 - 90%
