Intel Broadwell ULT processor
B50-50 is powered by Intel's new mobile processor – the Intel Broadwell ULT. This processor uses less power than the BayTrail T (far-left column) and allows Lenovo to aggressively attack the entry-level Windows OS tablet segment.
Thin and light
Thinner than 1" and small starting weight, it is easy to carry around. -
Great performance
Enjoy the power of the efficient processor, discrete graphics and more. -
15.6" widescreen display
The display delivers bright, crisp visuals in HD resolution. -
Enhanced graphics
With advanced graphics technology, you'll enjoy stunning visuals. -
Fast data transfer
Move data between the B50 and other devices quickly with USB 3.0. -
HDMI output
Easily connect to your TV or monitor for large-screen high-definition viewing. -
Swift connectivity
With 802.11 b/g/n Wi-Fi connectivity and Bluetooth 4.0, you'll be able to connect to the Internet wherever you go. -
Integrated webcam
The webcam helps to make your web conferences or online video chats a breeze.
- Lenovo B50-50 - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 500 GB Hybrid Drive - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB Hybrid Drive (8 GB flash) / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- 4-cell
- Black
- 37.8 cm x 26.5 cm x 2.29 cm
- 2.3 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5005U / 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB Hybrid Drive SATA 6Gb/s (8 GB flash) / 5400 rpm
- Optical Drive
- DVD-Writer
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 32 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Black
- Case Material
- Polycarbonate ABS
- Administrator password, hard drive password, power-on password
- Included Accessories
- Power adapter
- RoHS
- Localization
- 2.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- 0 °C
- 40 °C
- 10 - 90%
