Up to 5th Generation Intel® Core™ Processors
The new standard for PC performance has arrived with Intel® 6th Gen Core™ processors. This blazing fast, feature-packed processor family with built-in security is ready to take your productivity, creativity, and 3D gaming to the next level. What's more, by enabling the exciting Windows 10 features, 6th Gen Intel Core processors empower you to unleash your imagination and explore the possibilities.
Up to Windows 10 Home
Windows 10 Pro is designed to empower you and your business. It allows you to do great things across your devices securely with anyone, anywhere, and at any time. Fitting a variety of budgets, it's also very easy to use. So you can get more done right from the start.
Comfortable Viewing
The HD anti-glare display helps reduce eye fatigue, allowing you to work longer in comfort.
Thin and Light Design
Starting at a mere 2.3kg and just 22.9mm thick, the Lenovo B50 laptop is ready for productivity on the go.
Extra Peace of Mind
You can rest assured knowing your hardware is protected, thanks to the Kensington® Minisaver Cable Lock.
Connectivity Options
With 802.11 bgn WiFi and optional Bluetooth® 4.0, you can connect to the Internet wherever you go.
Integrated Webcam
The 0.3M webcam and microphone will help you enjoy web conferences or online video chats like you're really there.
Fast Data Transfer
Move data between the Lenovo B50 and other devices quickly with USB 3.0. Up to ten times faster than previous USB technologies, it's also backward-compatible.
Ample Storage
With storage up to 1TB HDD, you won't have to worry about where to put all your data, videos, music, and photos.
HDMI Port
Stream content quickly and easily from your Lenovo B50 to a television or other display.
Thin and light
Thinner than 1" and small starting weight, it is easy to carry around. -
Great performance
Enjoy the power of the efficient processor, discrete graphics and more. -
15.6" widescreen display
The display delivers bright, crisp visuals in HD resolution. -
Enhanced graphics
With advanced graphics technology, you'll enjoy stunning visuals. -
Fast data transfer
Move data between the B50 and other devices quickly with USB 3.0. -
HDMI output
Easily connect to your TV or monitor for large-screen high-definition viewing. -
Swift connectivity
With 802.11 b/g/n Wi-Fi connectivity and Bluetooth 4.0, you'll be able to connect to the Internet wherever you go. -
Integrated webcam
The webcam helps to make your web conferences or online video chats a breeze.
- Lenovo B50-50 - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- 4-cell
- 37.8 cm x 26.5 cm x 2.29 cm
- 2.3 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5005U / 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 5400 rpm
- Optical Drive
- DVD-Writer
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 32 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Administrator password, hard drive password, power-on password
- Included Accessories
- Power adapter
- RoHS
- Localization
- 2.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
