Your basket is empty
Lenovo 8GB TruDDR4 Memory (1Rx4, 1.2V) PC4-17000 CL15 2133MHz LP RD
Quicklinx: BZWNWS00 Mfr#: 46W0788
Upgrading your memory is a cost-effective way to improve system performance when insufficient memory and hard drive paging is slowing your applications down.
  • Faster start-up times with fewer delays during routine operations.
  • More programs running simultaneously.
  • Easy toggling between several open applications.
  • Rigorous supplier qualification processes for ensured quality.
Lenovo TruDDR4 - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Single rank, registered
Voltage
1.2 V
IBM 46W0788
1 year warranty
Flex System x240 M5 9532; System x3550 M5 5463; x3650 M5 5462; x3850 X6 6241; x3950 X6 6241
8 GB
Upgrade Type
System specific
IBM 46W0788
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Chips Organization
X4
Voltage
1.2 V
1 year warranty
Lenovo Flex System x240 M5 9532 , Lenovo System x3550 M5 5463 , Lenovo System x3650 M5 5462 , Lenovo System x3850 X6 6241 , Lenovo System x3950 X6 6241
