PC3-12800 DDR3-1600 UDIMM memory offerings let you upgrade your system's standard memory capacity to improve overall ThinkCentre or ThinkStation system performance. Adding additional memory is a cost-effective way to help boost your system's performance and enhance its ability to run more programs simultaneously.
- Lenovo - DDR3 - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- Designed For
- S500; ThinkCentre E73; ThinkCentre Edge 72; 92; ThinkCentre M72e; M73; M78; M79; M82; M83; M91; M91p; M92; M92p; M93; M93p; ThinkStation E30; E31; E32; P300
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Lenovo S500 10HS, 10HV , Lenovo ThinkCentre E73 10AS, 10AU , Lenovo ThinkCentre Edge 72 3484, 3492, 3493, 3497 , Lenovo ThinkCentre Edge 92 3387, 3388 , Lenovo ThinkCentre M72e 0896, 0900, 0958, 0967, 3578, 3597, 3598, 3655, 3660, 3662, 3664, 3665, 3668, 3675 , Lenovo ThinkCentre M73 , Lenovo ThinkCentre M78 10BN, 10BQ, 10BR, 10BS, 10BT, 10BU , Lenovo ThinkCentre M79 , Lenovo ThinkCentre M82 2697, 2742, 2750, 2756, 2929, 2932, 3302, 3306, 3392, 3395 , Lenovo ThinkCentre M83 10AJ , Lenovo ThinkCentre M91 , Lenovo ThinkCentre M91p , Lenovo ThinkCentre M92 3207, 3208 , Lenovo ThinkCentre M92p 2988, 2992, 2996, 2999, 3209, 3212, 3218, 3227, 3228 , Lenovo ThinkCentre M93 10A0, 10A2, 10A3 , Lenovo ThinkCentre M93p 10A7, 10A9 , Lenovo ThinkStation E30 7782, 7783, 7824 , Lenovo ThinkStation E31 2552, 2553, 2555, 3688, 3690, 3691, 3695 , Lenovo ThinkStation E32 30A1, 30A3 , Lenovo ThinkStation P300 30AH, 30AK
