Lenovo 8GB DDR4 2133 MHz DIMM 288-pin 1.2 V Registered ECC
Quicklinx: C8VDWS00 Mfr#: 4X70G78061
Adding more memory increases system performance. This 8 GB DDR4 2133 Mhz ECC RDIMM allows you to take advantage of the ThinkStation P500/P700/P900 system's full potential when working with 3D imaging, digital content creation, multimedia and other memory-intensive applications.
Lenovo - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
Lenovo 4X70G78061
3-year warranty
ThinkStation P500 30A7; P510 30B5; P700 30A8, 30A9; P710 30B6, 30B7; P900 30A4, 30A5; P910 30B8, 30B9
8 GB
Upgrade Type
System specific
Lenovo 4X70G78061
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.21
Speed
Latency Timings
CL15
ECC
Registered
Voltage
1.2 V
3-year warranty
Lenovo ThinkStation P500 30A7 , Lenovo ThinkStation P510 30B5 , Lenovo ThinkStation P700 30A8, 30A9 , Lenovo ThinkStation P710 30B6, 30B7 , Lenovo ThinkStation P900 30A4, 30A5 , Lenovo ThinkStation P910 30B8, 30B9
