Lenovo 500e Chromebook (2nd Gen) Intel Celeron N4100 4GB 32GB 11.6"
Quicklinx: FFVJWS00 Mfr#: 81MC0008UK
  • Celeron
  • IEEE 802.11n
The 500e Chromebook (2nd Gen) perfectly blends on-the-go technology with powerful processing and a premium classroom experience. Thanks to a 360-degree hinge, it can be used in four ways and there's a digital pen for on-screen writing and notetaking. This 11.6" 2-in-1 is rugged enough to handle whatever the school day brings.
  • Pen that's mightier than the keyboard
    The 500e Chromebook (2nd Gen) has its own electro-magnetic resonance pen. Pressure-sensitive and highly accurate, it's ideal for taking notes, writing, drawing, and even for showing workings in math. Delivering a real pen-like experience, it needs no charging or pairing so can be shared among students and across compatible devices. When not in use, it's housed inside the Chromebook.
  • Connect more, capture more
    With two HD cameras, the 500e Chromebook (2nd Gen) enhances collaboration and creativity. The 720p front-facing camera is great for video conferencing, while the 5 MP world-facing camera on the keyboard makes it easier for you to record the world around you.
  • Device you can count on
    Thanks to Corning Gorilla Glass 3 with Native Damage Resistance, the 11.6" HD screen is able to resist the kind of deep chips and scratches that cause regular glass to break. What's more, the 500e Chromebook (2nd Gen) has military-grade durability - with rubber bumpers, reinforced ports and hinges, and mechanically anchored keys.
  • As flexible as your imagination
    The unique 360-degree hinge allows the 500e Chromebook (2nd Gen) to adapt to different learning environments. Laptop mode is great for research, Tent mode for presentations, Stand mode for watching lectures, and Tablet mode for taking notes. The variety helps make learning more fun.
Lenovo 500e Chromebook (2nd Gen) - 11.6" - Celeron N4100 - 4 GB RAM - 32 GB eMMC - UK
Chromebook - flip design
Operating System
Chrome OS - English
Intel Celeron N4100 / 1.1 GHz (2.4 GHz) / 4 MB Cache
4 GB LPDDR4 (provided memory is soldered)
Storage
32 GB - eMMC eMMC 5.1
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel UHD Graphics 600
Input Device
Digitizer, digital pen
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 10 hours
Security
Google Security Chip H1
29 cm x 20.4 cm x 2.035 cm
1.31 kg
Environmental Standards
TCO Certified Notebooks 8
SAR
0.63 W/kg (body), 0.63 W/kg (limb)
Limited warranty - 1 year - pick-up and return
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
LPDDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
Storage
Main Storage
32 GB SSD - (eMMC) - eMMC 5.1
Display
11.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Bezel Type
Raised
Anti-fingerprint
Audio & Video
Graphics Processor
Camera
Yes - 720p (front)
Resolution
5 Megapixel (rear)
Sound
Stereo speakers, microphone
Codec
MAX98357A
Input
Keyboard, digitizer, touchpad, digital pen
Keyboard Layout
Spill-resistant, anti-pry key caps
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - M.2 Card
Lithium Ion
42 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
2 x USB-C 3.0 , 2 x USB 3.0 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Case Material
Polycarbonate ABS
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter, Lenovo Chrome Pen
RoHS
SAR Value
Localization
1.31 kg
TCO Certified
FFVJ Lenovo Optical 3-button W/Mouse USB In Stock £13.83
