Product
Brand
Lenovo 4GB DDR3L-1600MHz (1Rx8) ECC UDIMM Memory Module
Quicklinx: 9G3JWS00 Mfr#: 0C19499
Memory is one of the most vital components to keep your ThinkServer operating at maximum performance and push the boundaries of productivity for all of your server applications such as virtualization, e-commerce, or file and print services.
The ThinkServer DDR3 memory enables high I/O data transfer rate and reduced power consumption. Faster data transfer rates mean higher performance, and with DDR3 memory this is achieved without straining the system's power needs.
Lenovo - DDR3L - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Single rank, Low Voltage, unbuffered
Voltage
1.35 V
1 year warranty
ThinkServer RS140 70F2, 70F3, 70F8, 70F9; TD340 70B5, 70B6, 70B7; TS130 1098, 1100, 1105, 1106; TS140 70A0, 70A1, 70A4, 70A5; TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441; TS440 70AL, 70AM, 70AN, 70AQ
4 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.2
Speed
ECC
Chips Organization
X8
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
1 year warranty
Lenovo ThinkServer RS140 70F2, 70F3, 70F8, 70F9 , Lenovo ThinkServer TD340 70B5, 70B6, 70B7 , Lenovo ThinkServer TS130 1098, 1100, 1105, 1106 , Lenovo ThinkServer TS140 70A0, 70A1, 70A4, 70A5 , Lenovo ThinkServer TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441 , Lenovo ThinkServer TS440 70AL, 70AM, 70AN, 70AQ
