Lenovo 1TB ThinkPad USB 3.0 Secure 2.5" Portable Hard Drive
Quicklinx: 8P5WWS00 Mfr#: 0A65621
Form Factor: 2.5
Capacity: 1TB
Interface: SuperSpeed USB
£186.32 ex VAT
£223.58 inc VAT
Optimized for safeguarding essential data while on-the-go, the ThinkPad USB 3.0 1TB Secure Hard Drive offers high-level 256-bit Advanced Encryption Standard (AES) security within a slim, lightweight, self-powered, easy-to-use design.- Connectivity via either USB 2.0 or USB 3.0 (2) interface
  • Compact size
  • No requirement for an ac power adapter
  • Driverless operation under Microsoft Windows 7, Windows XP and Vista
  • All stored data is fully encrypted using the AES 256-bit security encryption algorithm
  • Real-time encryption with no read/write speed impact
  • Shock-mounted 1TB 5400 rpm hard drive capacity
  • Built-in USB 3.0 cable with an integral storage slot
  • Integrated high quality metal dome switch keypad for entering an 8 to 16 digit password for 1 user ID and 1 administrator ID
  • USB Y extension cable to ensure adequate power
  • Attractive protective carrying case
  • Non-skid anti-vibration pads
  • High quality ThinkPad soft touch paint
  • Multi-colored LED device status indicator
The ThinkPad USB 3.0 1TB Secure Hard Drive option also enables
  • Easy and secure storage expansion
  • No software installation and no power adapter required for operation
  • Built-in administrative password management
  • Simple file backup
Lenovo ThinkPad USB 3.0 Secure - hard drive - 1 TB - USB 3.0 - CRU
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, password authentication, 256-bit AES
Power Source
USB bus
8.69 cm x 12.203 cm x 1.925 cm
216 g
Pricing Type
Customer-replaceable Unit (CRU)
3-year warranty
1 TB
USB 3.0
8.69 cm
12.203 cm
1.925 cm
216 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Max Data Transfer Rate
75 MB/s
Data Transfer Rate Details
USB 3.0 (read): 75 MB/s , USB 3.0 (write): 55 MB/s , USB 2.0 (read): 33 MB/s , USB 2.0 (write): 25 MB/s
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Carrying case
1 x USB cable - integrated , 1 x USB extension cable - external
UL, VCCI, C-Tick, BSMI, cUL, FCC, ICES
Pricing Type
Limited warranty - 3 years
5 °C
55 °C
5 - 95%
Form Factor: 2.5
Capacity: 1TB
Brand: Lenovo
