Lenovo 1TB ThinkPad USB 3.0 Secure 2.5" Portable Hard Drive
Quicklinx: 8P5WWS00 Mfr#: 0A65621
Form Factor: 2.5"
Capacity: 1TB
Interface: SuperSpeed USB
More than 50 in stock
£181.34 ex VAT
£217.60 inc VAT
Optimized for safeguarding essential data while on-the-go, the ThinkPad USB 3.0 1TB Secure Hard Drive offers high-level 256-bit Advanced Encryption Standard (AES) security within a slim, lightweight, self-powered, easy-to-use design.- Connectivity via either USB 2.0 or USB 3.0 (2) interface
  • Compact size
  • No requirement for an ac power adapter
  • Driverless operation under Microsoft Windows 7, Windows XP and Vista
  • All stored data is fully encrypted using the AES 256-bit security encryption algorithm
  • Real-time encryption with no read/write speed impact
  • Shock-mounted 1TB 5400 rpm hard drive capacity
  • Built-in USB 3.0 cable with an integral storage slot
  • Integrated high quality metal dome switch keypad for entering an 8 to 16 digit password for 1 user ID and 1 administrator ID
  • USB Y extension cable to ensure adequate power
  • Attractive protective carrying case
  • Non-skid anti-vibration pads
  • High quality ThinkPad soft touch paint
  • Multi-colored LED device status indicator
The ThinkPad USB 3.0 1TB Secure Hard Drive option also enables
  • Easy and secure storage expansion
  • No software installation and no power adapter required for operation
  • Built-in administrative password management
  • Simple file backup
Lenovo ThinkPad USB 3.0 Secure - hard drive - 1 TB - USB 3.0 - CRU
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, password authentication, 256-bit AES
Power Source
USB bus
8.69 cm x 12.203 cm x 1.925 cm
216 g
Pricing Type
Customer-replaceable Unit (CRU)
3-year warranty
100e Chromebook Gen 3; 500e Chromebook Gen 3; IdeaPad 3 14IGL05; 3 15IGL05; IdeaPad Duet 3 10; IdeaPad S145-14; S740-15; IdeaPad Slim 7 14ARE05; Legion 5 15IMH05; 5P 15ARH05; ThinkCentre M60; M70; M70q Gen 2; M75q Gen 2; M75s Gen 2; M75t Gen 2; M80; M90; M90s Gen 2; M90t Gen 2; ThinkEdge SE30; SE50; ThinkPad E14 Gen 2; E14 Gen 3; E15 Gen 2; E15 Gen 3; L13 Gen 2; L13 Yoga Gen 2; L14 Gen 2; L15 Gen 2; P1 (4th Gen); P14s Gen 1; P14s Gen 2; P15s Gen 2; T14 Gen 2; T14s Gen 2; T15 Gen 2; X1 Carbon Gen 9; X1 Extreme Gen 4; X1 Titanium Yoga Gen 1; X1 Yoga Gen 6; X12 Detachable; X13 Yoga Gen 2; V14 IGL; V30a-22IIL AIO; V30a-24IIL AIO; V330-20ICB AIO; V50s-07; V50t Gen 2 13; V50t-13
1 TB
USB 3.0
8.69 cm
12.203 cm
1.925 cm
216 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Max Data Transfer Rate
75 MB/s
Data Transfer Rate Details
USB 3.0 (read): 75 MB/s , USB 3.0 (write): 55 MB/s , USB 2.0 (read): 33 MB/s , USB 2.0 (write): 25 MB/s
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Carrying case
1 x USB cable - integrated , 1 x USB extension cable - external
UL, VCCI, C-Tick, BSMI, cUL, FCC, ICES
Pricing Type
Limited warranty - 3 years
5 °C
55 °C
5 - 95%
Lenovo 100e Chromebook Gen 3 82J7, 82J8 , Lenovo 500e Chromebook Gen 3 82JB, 82JC , Lenovo IdeaPad 3 15IGL05 82BU , Lenovo IdeaPad S145-14IKB 81VB , Lenovo IdeaPad S740-15IRH 81NY , Lenovo IdeaPad Slim 7 14ARE05 82A5 , Lenovo Legion 5 15IMH05H 82CF , Lenovo Legion 5P 15ARH05H 82GU , Lenovo ThinkCentre M60e 11LU, 11LV , Lenovo ThinkCentre M70a 11E3 , Lenovo ThinkCentre M70c 11GK , Lenovo ThinkCentre M70q 11DV , Lenovo ThinkCentre M70q Gen 2 11MY, 11N0 , Lenovo ThinkCentre M70t 11EV , Lenovo ThinkCentre M75q Gen 2 11JM , Lenovo ThinkCentre M75s Gen 2 11JA, 11JC, 11JD , Lenovo ThinkCentre M75t Gen 2 11KB, 11KC , Lenovo ThinkCentre M80q 11EG, 11Q9, 11QA , Lenovo ThinkCentre M90a 11E0 , Lenovo ThinkCentre M90q 11DH, 11F0 , Lenovo ThinkCentre M90s 11D6 , Lenovo ThinkCentre M90s Gen 2 11L6 , Lenovo ThinkCentre M90t Gen 2 11L4 , Lenovo ThinkEdge SE30 11NA, 11NB, 11NC , Lenovo ThinkEdge SE50 11RJ , Lenovo ThinkPad E14 Gen 2 20TB , Lenovo ThinkPad E14 Gen 3 20Y7, 20YD , Lenovo ThinkPad E15 Gen 2 20TE , Lenovo ThinkPad E15 Gen 3 20YG , Lenovo ThinkPad L13 Gen 2 20VH, 20VJ, 21AB, 21AC , Lenovo ThinkPad L13 Yoga Gen 2 20VK, 20VL, 21AD , Lenovo ThinkPad L14 Gen 2 20X1, 20X2, 20X5, 20X6 , Lenovo ThinkPad L15 Gen 2 20X3, 20X4, 20X7, 20X8 , Lenovo ThinkPad P1 (4th Gen) 20Y3 , Lenovo ThinkPad P14s Gen 1 20Y2 , Lenovo ThinkPad P14s Gen 2 20VX, 20VY, 21A0, 21A1 , Lenovo ThinkPad P15s Gen 2 20W6, 20W7 , Lenovo ThinkPad T14 Gen 2 20W0, 20W1, 20XK, 20XL , Lenovo ThinkPad T14s Gen 2 20WM, 20WN , Lenovo ThinkPad T15 Gen 2 20W4, 20W5 , Lenovo ThinkPad X1 Carbon Gen 9 20XW, 20XX , Lenovo ThinkPad X1 Extreme Gen 4 20Y5, 20Y6 , Lenovo ThinkPad X1 Titanium Yoga Gen 1 20QA, 20QB , Lenovo ThinkPad X1 Yoga Gen 6 20XY, 20Y0 , Lenovo ThinkPad X12 Detachable 20UV, 20UW , Lenovo ThinkPad X13 Yoga Gen 2 20W8, 20W9 , Lenovo V14 IGL 82C2 , Lenovo V330-20ICB AIO , Lenovo V50s-07IMB 11EE, 11HA , Lenovo V50t Gen 2 13IOB 11QE , Lenovo V50t-13IMB 11ED, 11HD
Form Factor: 2.5"
Capacity: 1TB
Brand: Lenovo
Stock Status: In stock
