Lenovo 14w AMD A6-9220C 4GB 128GB SSD 14" Windows 10 Pro Academic
Quicklinx: FDGRWS00 Mfr#: 81MQ000DUK
Display Size: 14in
Processor Model: A6-9220C
Operating System: Windows 10 Pro National Academic
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 128GB
  • IEEE 802.11n
10 in stock
£280.61 ex VAT
£336.73 inc VAT
Introducing the Lenovo 14w, the laptop of choice for higher education teachers and administrators. Fueled by powerful processing, this device has an all-school-day battery life.
  • Easy on the eyes
    Behind the stamped aluminum shell cover, the display boasts a narrow bezel, plus IPS and anti-glare technology. The result is a larger, more vibrant screen with wide-angle viewing that's less of a strain on your eyes.
  • Because things happen
    With incredible durability, the 14w can more than handle the bumps and knocks of everyday life. Its full-sized keyboard and mechanically anchored keys are spill resistant.
  • Bringing everyone closer together
    With two microphones, the front-facing camera enables closer collaboration from across the room - or across the globe. Easy to use, it makes video-conferencing a breeze and more rewarding for everyone.
  • Leave the power cord at home
    On a single charge, the 14w can run for many hours. It's more than enough for your daily commute, and for you to get everything done at school or work once you're there.
Lenovo 14w - 14" - A6 9220C - 4 GB RAM - 128 GB eMMC - UK
Notebook
Operating System
Windows 10 Pro National Academic - English
AMD A6 9220C / 1.8 GHz (2.7 GHz) / 1 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
128 GB - eMMC eMMC 5.1
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon R5
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 12 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.8 cm x 22.5 cm x 1.77 cm
1.54 kg
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
1 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
1666 MHz
Rated Speed
1666 MHz
Storage
Main Storage
128 GB SSD - (eMMC) - eMMC 5.1
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
AMD Radeon R5
Camera
Yes - 720p
Sound
Stereo speakers, array microphone
Codec
DA7219
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant
Communications
Wireless
Wireless Controller
Atheros QCA6174A - M.2 Card
Lithium Ion
57 Wh
Run Time
Up to 12 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
USB-C 3.0 , 2 x USB 3.0 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Case Material
Polycarbonate ABS
Security
Administrator password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
1.54 kg
Software applications
Lenovo 14w AMD A6-9220C 4GB 128GB SSD 14 Bundle deal on Lenovo 14w AMD A6-9220C 4GB 128GB SSD 14" Windows 10 Pro Academic
£463.77
saving £8.33
£379.78
FDGR Lenovo Optical 3-button W/Mouse USB In Stock £13.83
Display Size: 14in
Optical Storage: None
Graphics: AMD Radeon R5
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: Lenovo
Price Range Ex VAT: 150 - 300
