Meet the Lenovo 14e Chromebook, a powerful, versatile Chromebook with high-performance processing. The possibilities it gives to students, teachers, and businesses are endless.
Multitask with ease
Open as many windows as you like, run multiple apps, play high-definition videos, or stream your favorite TV shows. Whatever task you want to accomplish, the 14e Chromebook will perform smoothly - without compromising a thing. -
Easy on the eyes
Behind the stamped aluminum shell cover, the 14" FHD display boasts a narrow bezel and antiglare technology. The result is a larger, more vibrant screen with wide-angle viewing that's less of a strain on your eyes. -
No more crying over spilled coffee
The full-sized keyboard includes a sealed touchpad that can resist spills of up to 1.39 cups (330 ml). It also boasts mechanically anchored keys that stay put regardless of the bumps and knocks of daily life. -
Bring people and ideas closer
The front-facing 720p HD camera comes with two microphones, making videoconferencing or chatting a breeze. What's more, everything sounds and looks crystal clear, enabling closer collaboration - even from across the globe. -
Built to last
The 14e Chromebook includes reinforced ports and hinges, mechanically anchored keys, and a spill-resistant keyboard. It has military-grade durability and is MIL-SPEC tested to handle all kinds of things - even being bumped or dropped from up to 29.5" (75 cm).
- Lenovo 14e Chromebook - 14" - A4 9120C - 4 GB RAM - 64 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS - English
- Processor
- AMD A4 9120C / 1.6 GHz (2.4 GHz) / 1 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 14" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- AMD Radeon R4
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- Up to 10 hours
- Mineral grey
- 32.8 cm x 22.5 cm x 1.77 cm
- 1.48 kg
- Localisation
- Environmental Standards
- TCO Certified Notebooks 8
- SAR
- 0.38 W/kg (body), 0.38 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Chromebook
- Operating System
- Google Chrome OS - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 1 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 1666 MHz
- Rated Speed
- 1666 MHz
Storage
- Main Storage
- 64 GB SSD eMMC - eMMC 5.1
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Bezel Type
- Raised
- Anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R4
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- DA7219
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, buttonless touchpad, anti-pry key caps
Communications
- Wireless
- Wireless Controller
- Qualcomm QCA6174A - M.2 Card
- Technology
- Lithium Ion
- Capacity
- 57 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- 2 x USB 3.0 , 2 x USB-C 3.0 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Mineral grey
- Case Material
- Polycarbonate ABS
- Google H1 security chip
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS, MIL-STD 810G
- SAR Value
- Localization
- 1.48 kg
- TCO Certified
