Lenovo 14e Chromebook AMD A4-9120C 4GB 64GB 14" Touchscreen
Quicklinx: FFVNWS00 Mfr#: 81MH0002UK
Display Size: 14in
Processor Model: A4-9120C
Operating System: Google Chrome OS
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 64GB
  • IEEE 802.11n
2 on order, no confirmed delivery date
£279.47 ex VAT
£335.36 inc VAT
Meet the Lenovo 14e Chromebook, a powerful, versatile Chromebook with high-performance processing. The possibilities it gives to students, teachers, and businesses are endless.
  • Multitask with ease
    Open as many windows as you like, run multiple apps, play high-definition videos, or stream your favorite TV shows. Whatever task you want to accomplish, the 14e Chromebook will perform smoothly - without compromising a thing.
  • Easy on the eyes
    Behind the stamped aluminum shell cover, the 14" FHD display boasts a narrow bezel and antiglare technology. The result is a larger, more vibrant screen with wide-angle viewing that's less of a strain on your eyes.
  • No more crying over spilled coffee
    The full-sized keyboard includes a sealed touchpad that can resist spills of up to 1.39 cups (330 ml). It also boasts mechanically anchored keys that stay put regardless of the bumps and knocks of daily life.
  • Bring people and ideas closer
    The front-facing 720p HD camera comes with two microphones, making videoconferencing or chatting a breeze. What's more, everything sounds and looks crystal clear, enabling closer collaboration - even from across the globe.
  • Built to last
    The 14e Chromebook includes reinforced ports and hinges, mechanically anchored keys, and a spill-resistant keyboard. It has military-grade durability and is MIL-SPEC tested to handle all kinds of things - even being bumped or dropped from up to 29.5" (75 cm).
Lenovo 14e Chromebook - 14" - A4 9120C - 4 GB RAM - 64 GB eMMC - UK
Chromebook
Operating System
Chrome OS - English
AMD A4 9120C / 1.6 GHz (2.4 GHz) / 1 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
64 GB eMMC
Display
14" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
AMD Radeon R4
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 10 hours
Mineral grey
32.8 cm x 22.5 cm x 1.77 cm
1.48 kg
Environmental Standards
TCO Certified Notebooks 8
SAR
0.38 W/kg (body), 0.38 W/kg (limb)
Limited warranty - 1 year - pick-up and return
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
1666 MHz
Rated Speed
1666 MHz
Storage
Main Storage
64 GB SSD eMMC - eMMC 5.1
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Bezel Type
Raised
Anti-glare
Audio & Video
Graphics Processor
AMD Radeon R4
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
DA7219
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant, buttonless touchpad, anti-pry key caps
Communications
Wireless
Wireless Controller
Qualcomm QCA6174A - M.2 Card
Lithium Ion
57 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
2 x USB 3.0 , 2 x USB-C 3.0 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Mineral grey
Case Material
Polycarbonate ABS
Google H1 security chip
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS, MIL-STD 810G
SAR Value
Localization
1.48 kg
TCO Certified
Display Size: 14in
Optical Storage: None
Graphics: AMD Radeon R4
Hard Drive Type: SSD
Brand: Lenovo
Price Range Ex VAT: 150 - 300
