Lenovo 110-15ACL AMD A6-7310 8GB 1TB 15.6" Windows 10 Home
Quicklinx: C9MRWS00 Mfr#: 80TJ001PUK
  • IEEE 802.11n
  • Bluetooth 4.0
The affordable Lenovo ideapad 110 notebooks combine a slim 22.9 mm design with features such as an integrated DVD drive and an Intel processor, as well as AMD R5 430M graphics.
  • Powered for fun
    The Ideapad 110 is powered by fast processor with integrated graphics, giving you plenty of processing power for casual surfing, streaming, and playing.
  • Lightning-fast web browsing
    802.11 a/c Wi-Fi connectivity comes standard on the Ideapad 110, making it perfect for blazing-fast browsing, streaming, and downloading. 802.11 a/c WiFi delivers faster connection speeds.
  • Productivity and comfort
    The Ideapad 110 has a number of features to maximize your productivity and comfort. The improved hinge design is more robust and allows for smooth 180ยบ action to a flat position. The frameless keyboard allows your fingers to move freely without bumping, and the textured palm rest resists fingerprints.
  • Integrated optical drive
    There's no need to get an external optical drive with the Ideapad 110. It comes standard with an integrated DVD/CD-RW drive so you can load programs, listen to CDs, or watch movies offline.
Lenovo IdeaPad 110-15ACL - 15.6" - AMD A6 - 7310 - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 10 Home 64-bit - English
AMD A6 7310 / 2 GHz, up to 2.4 GHz / 2 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R4
Keyboard
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, 10/100 Ethernet
3-cell - up to 3 hours
37.8 cm x 26.5 cm x 2.29 cm
2.2 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
AMD A6 7310 / 2 GHz
Max Turbo Speed
2.4 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Integrated memory controller, AMD Turbo CORE technology
RAM
8 GB (1 x 8 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 5400 rpm
Optical Drive
DVD-Writer - tray
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare
Audio & Video
Graphics Processor
AMD Radeon R4
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Realtek RTL8821AE
Network Interface
10/100 Ethernet
3-cell Lithium Ion
24 Wh
Run Time
Up to 3 hours
Battery Run Time
Video playback: up to 3 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
Power adapter
Localization
2.2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
