The affordable Lenovo ideapad 110 notebooks combine a slim 22.9 mm design with features such as an integrated DVD drive and an Intel processor, as well as AMD R5 430M graphics.
Powered for fun
The Ideapad 110 is powered by fast processor with integrated graphics, giving you plenty of processing power for casual surfing, streaming, and playing. -
Lightning-fast web browsing
802.11 a/c Wi-Fi connectivity comes standard on the Ideapad 110, making it perfect for blazing-fast browsing, streaming, and downloading. 802.11 a/c WiFi delivers faster connection speeds. -
Productivity and comfort
The Ideapad 110 has a number of features to maximize your productivity and comfort. The improved hinge design is more robust and allows for smooth 180ยบ action to a flat position. The frameless keyboard allows your fingers to move freely without bumping, and the textured palm rest resists fingerprints. -
Integrated optical drive
There's no need to get an external optical drive with the Ideapad 110. It comes standard with an integrated DVD/CD-RW drive so you can load programs, listen to CDs, or watch movies offline.
- Lenovo IdeaPad 110-15ACL - 15.6" - AMD A6 - 7310 - 8 GB RAM - 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- AMD A6 7310 / 2 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R4
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, 10/100 Ethernet
- Battery
- 3-cell - up to 3 hours
- Black
- 37.8 cm x 26.5 cm x 2.29 cm
- 2.2 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Integrated memory controller, AMD Turbo CORE technology
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 1 TB HDD SATA 6Gb/s / 5400 rpm
- Optical Drive
- DVD-Writer - tray
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R4
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Realtek RTL8821AE
- Network Interface
- 10/100 Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 24 Wh
- Run Time
- Up to 3 hours
- Battery Run Time
- Video playback: up to 3 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Black
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter
- Localization
- 2.2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
