Lenovo  ThinkVision S27q-10 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: FPVBWS00 Mfr#: 61E8GAT1UK
Enhance your viewing experience with the ThinkVision S27q monitor that delivers impeccable visuals. The 27-inch, In-Plane Switching (IPS) panel offers wide viewing angles with vivid display quality. The QHD display ensures superior clarity and helps you work efficiently. Eye care technology on the S27q reduces eye fatigue, adding longer hours of productivity. High picture quality with superior color support makes this monitor a smart choice for businesses and freelancers. No matter what you are working on - be it data analytics, accounting, or designing - this monitor will delight you with its excellent color performance.
  • Improved visual clarity and comfort
    The QHD display with In-Plane Switching (IPS) panel provides wide viewing angles for enhanced visual clarity. Experience unmatched brightness and vivid details with > 99% accurate sRGB gamut and 1.07 Billion color support while editing images, or working on spreadsheets. The TÜV Eye Comfort-certified monitor reduces flicker levels and blue light radiation, minimizing eye fatigue.
  • Organized and efficient workspace
    The 3-sided NearEdgeless bezel provides a wide screen real estate for seamless multitasking. Adjust the monitor to suit your work style with the quick-release tilt stand. The cable management feature and VESA mount - that allows you to fix the monitor on the wall - ensure a clutter-free workspace.
  • Seamless interfacing and connectivity
    Share your ideas, presentations, and documents with ease on the ThinkVision S27q that facilitates collaboration. The advanced connectivity via HDMI, DisplayPort, and Audio Out port allow you to extend or duplicate your PC for presentations or group discussions without compromising on visual quality.
Lenovo ThinkVision S27q-10 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
24.9 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 12 ms (Off), 6 ms (typical)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100/240 V (50/60 Hz)
Raven black
61.36 cm x 22 cm x 44.46 cm
4.65 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
CCC, RoHS 2002/95/IEC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
99% sRGB colour gamut
Raven black
61.36 cm x 22 cm x 44.46 cm - with stand
4.65 kg
DisplayPort , HDMI , Audio line-out (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
24.9 W
24.9 kWh/1000h
Power Consumption (Typical)
35 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7, Windows 10
Dimensions & Weight Details
With stand (highest position) - width: 61.36 cm - depth: 22 cm - height: 44.46 cm - weight: 4.65 kg , With stand (lowest position) - width: 61.36 cm - depth: 22 cm - height: 44.46 cm - weight: 4.65 kg , Without stand - width: 61.36 cm - depth: 4.2 cm - height: 36.76 cm - weight: 4.1 kg
Shipping Width
71.5 cm
Shipping Depth
13.2 cm
Shipping Height
45.5 cm
Shipping Weight
6.36 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
