Enhance your viewing experience with the ThinkVision S27q monitor that delivers impeccable visuals. The 27-inch, In-Plane Switching (IPS) panel offers wide viewing angles with vivid display quality. The QHD display ensures superior clarity and helps you work efficiently. Eye care technology on the S27q reduces eye fatigue, adding longer hours of productivity. High picture quality with superior color support makes this monitor a smart choice for businesses and freelancers. No matter what you are working on - be it data analytics, accounting, or designing - this monitor will delight you with its excellent color performance.
Improved visual clarity and comfort
The QHD display with In-Plane Switching (IPS) panel provides wide viewing angles for enhanced visual clarity. Experience unmatched brightness and vivid details with > 99% accurate sRGB gamut and 1.07 Billion color support while editing images, or working on spreadsheets. The TÜV Eye Comfort-certified monitor reduces flicker levels and blue light radiation, minimizing eye fatigue. -
Organized and efficient workspace
The 3-sided NearEdgeless bezel provides a wide screen real estate for seamless multitasking. Adjust the monitor to suit your work style with the quick-release tilt stand. The cable management feature and VESA mount - that allows you to fix the monitor on the wall - ensure a clutter-free workspace. -
Seamless interfacing and connectivity
Share your ideas, presentations, and documents with ease on the ThinkVision S27q that facilitates collaboration. The advanced connectivity via HDMI, DisplayPort, and Audio Out port allow you to extend or duplicate your PC for presentations or group discussions without compromising on visual quality.
- Lenovo ThinkVision S27q-10 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Power Consumption (On mode)
- 24.9 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 12 ms (Off), 6 ms (typical)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100/240 V (50/60 Hz)
- Raven black
- 61.36 cm x 22 cm x 44.46 cm
- 4.65 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- CCC, RoHS 2002/95/IEC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- 99% sRGB colour gamut
- Raven black
- 61.36 cm x 22 cm x 44.46 cm - with stand
- 4.65 kg
- DisplayPort , HDMI , Audio line-out (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 24.9 W
- Power Consumption SDR (On mode)
- 24.9 kWh/1000h
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows 7, Windows 10
- Dimensions & Weight Details
- With stand (highest position) - width: 61.36 cm - depth: 22 cm - height: 44.46 cm - weight: 4.65 kg , With stand (lowest position) - width: 61.36 cm - depth: 22 cm - height: 44.46 cm - weight: 4.65 kg , Without stand - width: 61.36 cm - depth: 4.2 cm - height: 36.76 cm - weight: 4.1 kg
- Shipping Width
- 71.5 cm
- Shipping Depth
- 13.2 cm
- Shipping Height
- 45.5 cm
- Shipping Weight
- 6.36 kg
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 3 years
