Your basket is empty
Leap Motion Mac & PC Motion Controller for Games, Design & More
Experience a New Way To Play, Create & Explore!
Quicklinx: 98QGWS00 Mfr#: LM-C01-UK
£49.99 ex VAT
£59.98 inc VAT
Introducing the Leap Motion Controller. With the wave of a hand or lift of a finger - experience a new way to play, create, and explore.
Explore space, sculpt art, and play games on your computer simply by moving your hands through the air. With over 150 apps in Airspace™, the Leap Motion app store, you'll find a wide range of apps to play, learn, and create in new and immersive ways. Throw your hands into making music, reach into learning, and grab hold of the game in a whole new way.
See our Hands On Leap Motion Controller Video
See The Leap Motion Controller In Action
The Leap Motion Controller tracks both hands and all 10 fingers with pinpoint precision and incredible speed. Just plug into your PC or Mac and launch Airspace, your home for Leap Motion apps.
In Airspace, the Leap Motion App store, you'll find a wide variety of specially designed free and paid apps for gaming, music, art creation, science, productivity and much more. Apps from the Airspace app store let you interact with your computer just by moving your hands through the air. Play, create, and explore in a whole new way!
To get you started, the Leap Motion Controller comes with a free set of apps included.
Product Features
  • A tiny device with huge possibilities: The device is sleek, light, and tiny (just 80mm long). It takes up hardly any space on your desk. The wide 150° field of view gives you .22 cubic meters of interactive, three-dimensional space.
  • Bring your game to the next level: Get way, way, more into the game. Use your hands to move in any direction, with precision. Dive into realistic, 3D interaction at its best. Steer, slice, grab, push, pull, crush, and shoot with your hands and finger. Try popular games from Airspace like Fruit Ninja, and Cut the Rope, or brand new experiences including Dropchord and Blue Estate.
  • Make a masterpiece out of thin air: With the Leap Motion Controller, you're the instrument. Strum, drum, sketch, draw, and paint with your fingers. Sculpt as easily as you would with clay. Or use your own pencils, paintbrushes, or drumsticks. Try out Decosketch, or master a rhythm with AirBeats. It's the best way to create just about anything, because you do it by hand.
  • Reach for the stars. Grab a planet while you're at it: When you learn about the world through 3D motion-control, life really comes alive. Move up, down, left, right, forward and back in Google Earth. Fly through space in Exoplanet, take apart a skull in Cyber Science or ssimply catch up on the latest news in the New York Times app. When you reach into your computer, the learning never stops.
  • It works with what you already have. (Hands and fingers included.) The Leap Motion Controller doesn't replace your keyboard, mouse, or trackpad. It works with them. With the Leap Motion software running, just plug it into the USB port on your Mac or PC, and you're off.
Minimum System Requirements
  • Compatibility: Windows 7 or 8 or Mac OS X 10.7 Mountain Lion
  • Hardware: AMD Phenom™ II or Intel® Core™ i3, i5 or i7 processor; 2GB RAM; USB 2.0 port; Internet connection
What's included
  • Leap MotionTM Controller
  • 2 Cords: 61cm (for laptops) and 152cm (for desktops)
  • Type of Cable: USB 2.0 (micro USB 3.0 connectors)
  • Connection Type: USB
Watch Video: Exploring With Leap Motion
Watch Video: Playing With Leap Motion
Watch Video: Creating With Leap Motion
Leap Motion Controller - 3D motion controller - USB
Wired - USB
8 cm x 3.05 cm x 1.27 cm
45.4 g
Accuracy
± 0.01 mm
Performance
200 reports per second
Microsoft Windows 7, Apple MacOS X 10.7 Lion, Windows 8
1 year warranty
8 cm
3.05 cm
1.27 cm
45.4 g
Input Device
Wired
USB
Accuracy
± 0.01 mm
Performance
1 x USB - 4 pin USB Type A
System Requirements Details
Windows 7/8 - Phenom II RAM 2 GB , Windows 7/8 - Intel Core RAM 2 GB , MacOS X 10.7 - Intel Core RAM 2 GB
Limited warranty - 1 year
Brand: Leap Motion
Price Range Ex VAT: 0 - 50
