The LaCie XtremKey is strongest, toughest USB key yet. With an impenetrable shell, the LaCie XtremKey is a truly rugged USB key that stands up to the elements. The XtremKey is constructed with zamac, a metal alloy composed of zinc, aluminum, magnesium and copper that's so strong, it can withstand the pressure of a 10-ton truck.
The XtremKey's memory modules are shielded inside of a 2mm casing and sealed with wear-resistant screw threads and a rubber O-ring, which makes it watertight up to 100 meters. In addition, it's resistant to 5-meter drops, fierce heat and bitter cold - it holds up in any environment, no matter where you take it (+200°C / -50°). Equipped with the Hi-Speed USB 2.0 interface, the LaCie XtremKey offers instant compatibility, outstanding transfer speeds and cross-platform convenience to all PC and Mac users. With speeds up to 30MB/s (write) and 40MB/s (read), you don't have to sacrifice performance for protection.
- LaCie XtremKey - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- OS Required
- Apple MacOS X 10.6, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- 256-bit AES
- Read Rate
- Up to 230 MB/s
- Interface Type
- USB 3.0
- Shockproof, waterproof
- Included Accessories
- Key ring
- IP68
- OS Required
- Limited warranty - 3 years
- 74 mm
- 22 mm
- 57 g
- 5 °C
- 35 °C
