Product
LaCie Rugged Thunderbolt 1TB External Hard Drive USB 3.0/Thunderbolt - 256-bit AES
Quicklinx: C94KWS00 Mfr#: STEV1000400
Deadlines rule our world. When digital storage is critical for your project, it had better be as fast and reliable as you are. From the desktop to the badlands, it has to connect to any computer, deliver more than enough speed for the most demanding applications, and protect data against any threat.
  • Universal connectivity
    Don't let your project get derailed by external drive/computer incompatibility. With both USB 3.0 and Thunderbolt interfaces, the LaCie Rugged is a perfect match for your Mac and PC. And because USB 3.0 is backwards compatible, you can connect it to any standard computer on the planet. The LaCie Rugged is also fully bus-powered through the included USB 3.0 and Thunderbolt cables. Its portability and interfaces make it the must-have sidekick to a new Mac or Ultrabook.
  • No-compromise speed
    Get lightning-fast transfer speeds on Mac and PC thanks to the USB 3.0 and Thunderbolt interfaces. Back up and transfer mountains of data in a fraction of the time. Enjoy noticeably more responsive photo library browsing.
LaCie Rugged Thunderbolt - hard drive - 1 TB - USB 3.0 / Thunderbolt
Hard drive - external (portable)
1 TB
Encryption Algorithm
256-bit AES
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Shock resistant, water resistant, password authentication, dust-proof, rugged, software encryption
Power Source
USB bus, Thunderbolt bus
88.9 mm x 140 mm x 25 mm
220 g
Worldwide
2 years warranty
1 TB
256-bit AES
88.9 mm
140 mm
25 mm
220 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0 , 1 x Thunderbolt
Power Source
Software Included
LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.6 or later, Microsoft Windows 7 / 8 (32/64 bits)
Protective cover
1 x Thunderbolt cable - integrated , 1 x USB 3.0 cable - external
Worldwide
