Product
Brand
LaCie Lacie 12TB 2big Quadra USB 3
Quicklinx: D7SNWS00 Mfr#: STGL12000400
Stock Status: Clearance
Hurry, only 1 left in stock!
£376.77 ex VAT
£452.12 inc VAT
Express delivery Order within the next 22 hours for delivery on Wednesday
This quadruple interface professional 2-disk RAID delivers fast speed, large capacity and data security. With eSATA 3Gbits, FireWire 800, FireWire 400 and Hi-Speed USB 2.0, it provides complete universal compatibility with any PC or Mac. The easy-to-use 2big Quadra comes with two extractable, lockable and hot-swappable disks for a user-controlled solution. With four RAID levels, it meets your storage needs, whether it's security, capacity, speed or a combination. With burst transfer rates as high as 165MB/s (eSATA), it's ideal for audio/video projects. The sturdy heat sink metal design provides 60% more surface area for natural heat dissipation.
LaCie 2big Quadra - hard drive array
Hard drive array
Total Array Capacity
12 TB
FireWire 800, USB 3.0
2 (installed) / 2 (max)
Worldwide
Storage Controller
RAID 0, 1, 0+1
Hard Drive
2 x 6 TB HDD - hot-swap
Windows 8 or later, Apple MacOS 10.12 Sierra or later
AC 120/230 V - 50/60 Hz
9 cm x 20 cm x 18.2 cm
3.7 kg
3 years warranty
Hard drive array
Worldwide
Chassis
2
Supported Devices / Modules Qty
2
Storage
12 TB
HDD Array External Interface
Storage Controller
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, RAID 0+1
Hard Drive
HDD - hot-swap
2 x 6 TB
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0
Aluminum enclosure, built-in cooling fan, integrated cable management, kensington security slot
1 x USB 3.0 cable , 1 x IEEE 1394b cable , 1 x eSATA cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Desktop Manager
Stand
External power adapter
9 cm
20 cm
18.2 cm
3.7 kg
Limited warranty - 3 years
Brand: LaCie
Price Range Ex VAT: 300 - 500
