Think bigger - we've got you covered. With ample capacity on your desktop, up to 2600MB/s speeds, and RAID 5/6, the LaCie 12big and 6big Thunderbolt 3 lets you rein in the stampede of data from ultra hi-res cameras.
Extremely fast I/O
For the 6big and 12big, LaCie harnessed the breakthrough performance potential of the Thunderbolt 3 I/O and squeezed the absolute best speeds out of the hard drives. A hardware RAID controller was added and 7200RPM drives, and the result is astonishing 12big speeds of up to 2600MB/s - and 2400MB/s in RAID 5. -
For lightning-fast video workflows
That kind of speed can slash time off nearly every task in your post-production workflow. Ingest hours of RAW footage from a Blackmagic cinema camera into Adobe Premiere Pro in a fraction of the time. Then edit multiple streams of ProRes 422 (HQ), ProRes 4444 XQ, as well as uncompressed HD 10-bit and 12-bit video. For big projects packed with high-def clips, thumbnail and preview rendering becomes much more responsive. -
And for your smartest workspace
With double the video bandwidth of its predecessor, Thunderbolt 3 lets you daisy chain dual 4K displays or a single 5K display to the LaCie 12big or 6big. With two 4K displays, you can spread out your workspace by dedicating one display to your timeline and the other to previewing 4K footage, for example. It's even possible to power a compatible laptop through the Thunderbolt 3 connection.
- LaCie 12big Thunderbolt 3 - hard drive array
- Hard drive array
- Total Array Capacity
- 96 TB
- Interface
- USB 3.1, Thunderbolt 3
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- Supported Drives
- SATA
- Built-in Devices
- Led panel
- Storage Controller
- RAID RAID 0, 1, 5, 6, 10, 50
- Hard Drive
- 12 x 8 TB HDD - hot-swap - Enterprise Class Reliability, 24x7 continuous operation
- OS Required
- Apple MacOS X 10.10 or later, Windows 8 or later
- Power
- AC 120/230 V - 50/60 Hz
- 16.1 cm x 44.7 cm x 23.7 cm
- 17.6 kg
- 5 years warranty
- Hard drive array
Chassis
- Built-in Devices
- Led panel
- 12
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA
Storage
- 96 TB
- HDD Array External Interface
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 8 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 3.5"
- 2 x Thunderbolt 3 , 1 x USB 3.1 - 24 pin USB-C
- OS Required
- Audible alarm, redundant fans, e-mail notification, kensington security slot
- Cables Included
- 1 x USB-C cable , 1 x USB-C to USB-A cable
- Software Included
- Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
- AES-256
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 400 Watt
- 16.1 cm
- 44.7 cm
- 23.7 cm
- 17.6 kg
- Limited warranty - 5 years
