Get the job done faster - on any computer - with dual Thunderbolt 2 and USB 3.0. Thanks to its innovative, all-aluminum unibody design, you'll notice incredibly low vibration and operating noise.
Versatility for professional environments
The LaCie d2 combines Thunderbolt 2 and USB 3.0 interfaces to deliver fast speeds when connected to any PC or Mac computer. -
Innovative design
When recreating the industrial design of the d2, LaCie focused relentlessly on reliability and usability for professionals. -
Unibody enclosure
The casing is forged from a single sheet of aluminum, providing uncommon rigidity for long-term durability and premium quality.
- LaCie d2 Thunderbolt 2 - hard drive - 8 TB - USB 3.0 / Thunderbolt 2
- Hard drive - external (desktop)
- Capacity
- 8 TB
- Interface
- Data Transfer Rate
- 20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0)
- Spindle Speed
- 7200 rpm
- Power Source
- Included AC adapter
- 217 mm x 130 mm x 60 mm
- 1.7 kg
- Localisation
- Worldwide
- 5-year warranty
- Capacity
- 8 TB
- Interface
- 217 mm
- 130 mm
- 60 mm
- 1.7 kg
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 180 MB/s
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x USB 3.0 , 2 x Thunderbolt 2
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- OS Required
- Microsoft Windows 7 / Windows 8, Apple OS X 10.8.5 Mountain Lion or later
- Cables Included
- 1 x Thunderbolt cable , 1 x USB 3.0 cable
- Localisation
- Worldwide
- Limited warranty - 5 years
