The LaCie d2 Professional performs perfectly on Macs and PCs alike and features superior performance and reliability.
Robust capacity
With an 8 TB capacity, this external hard drive offers ample space for storing large files, ideal for professionals and creatives alike. -
High-speed transfers
Equipped with USB 3.1 Gen 2 interface, the LaCie d2 Professional ensures fast data transfer rates up to 240 MB/s, facilitating quick and efficient file access and backups. -
Enhanced durability
Features such as vibration dampening and an LED status indicator not only enhance the drive's reliability but also keep users informed about its operational status. -
Professional-grade design
The desktop external drive type, complemented by an included AC adapter and a sleek USB-C port, underscores its utility and ease of use.
 - LaCie d2 Professional STHA8000800 - hard drive - 8 TB - USB 3.1 Gen 2
 - Hard drive - external (desktop)
- Capacity
 - 8 TB
- Interface
 - USB 3.1 Gen 2 - USB-C
 - Security lock slot (cable lock sold separately), vibration dampening, LED status indicator, Enterprise
- Power Source
 - Included AC adapter
 - 130 mm x 60 mm x 188.5 mm
 - 1.4 kg
- Localisation
 - Worldwide
 - 5-year warranty
- Bundled with
 - Seagate Rescue Data Recovery
- Capacity
 - 8 TB
- Interface
 - USB 3.1 Gen 2
 - 130 mm
 - 60 mm
 - 188.5 mm
 - 1.4 kg
- Bundled with
Performance
- Max Data Transfer Rate
 - 240 MB/s
Expansion & Connectivity
 - 1 x USB 3.1 Gen 2 - 24 pin USB-C
- Power Source
- Power Device
 - Power adapter
- Voltage Required
 - AC 120/230 V (50/60 Hz)
- Software Included
 - Adobe Creative Cloud (30 days trial)
- OS Required
 - Apple macOS Sierra 10.12 or later, Windows 10 or later
- Localisation
 - Worldwide
- Shipping Width
 - 18 cm
- Shipping Depth
 - 24 cm
- Shipping Height
 - 12 cm
- Shipping Weight
 - 1.6 kg
 - Limited warranty - 5 years
