Product
LaCie 8TB 2big Quadra FireWire 800 & USB 3.0 7200RPM
Quicklinx: 9BW1WS00 Mfr#: LAC9000317
Form Factor: 3.5"
Capacity: 8TB
Interface: SuperSpeed USB
Hurry, only 2 left in stock!
£308.21 ex VAT
£369.85 inc VAT
This quadruple interface professional 2-disk RAID delivers fast speed, large capacity and data security. With eSATA 3Gbits, FireWire 800, FireWire 400 and Hi-Speed USB 2.0, it provides complete universal compatibility with any PC or Mac. The easy-to-use 2big Quadra comes with two extractable, lockable and hot-swappable disks for a user-controlled solution. With four RAID levels, it meets your storage needs, whether it's security, capacity, speed or a combination. With burst transfer rates as high as 165MB/s (eSATA), it's ideal for audio/video projects. The sturdy heat sink metal design provides 60% more surface area for natural heat dissipation.
LaCie 2big Quadra - hard drive array
Hard drive array
Total Array Capacity
8 TB
FireWire 800, USB 3.0
2 (installed) / 2 (max)
Storage Controller
RAID RAID 0, 1
Hard Drive
2 x 4 TB HDD - hot-swap
Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Microsoft Windows Vista / XP / 7 / 8, Apple MacOS X 10.8 or later
AC 120/230 V - 50/60 Hz
9.1 cm x 17.2 cm x 20 cm
3.6 kg
3 years warranty
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Storage
8 TB
HDD Array External Interface
Storage Controller
RAID - integrated
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1
Hard Drive
HDD - hot-swap
2 x 4 TB
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0
Aluminum enclosure
1 x USB 3.0 cable , 1 x IEEE 1394b cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Desktop Manager
Stand
External power adapter
9.1 cm
17.2 cm
20 cm
3.6 kg
Limited warranty - 3 years
Form Factor: 3.5"
Capacity: 8TB
Brand: LaCie
Price Range Ex VAT: 300 - 500
