With the LaCie Porsche Design Desktop Drive, LaCie offers a hard drive that's as powerful as it is beautiful. The LaCie Desktop Drive features a USB 3.0 interface for fast speeds plus a solid, aluminum casing that looks great.
Expansive storage
With a generous 6 TB capacity, this external desktop hard drive offers ample space for storing large files, high-resolution images, and backup data, making it a suitable solution for professionals and multimedia enthusiasts alike. -
High-speed connectivity
Equipped with USB 3.1 interface, the LaCie Porsche Design Desktop Drive ensures fast data transfer speeds of up to 5.0 Gbps with USB 3.0, significantly reducing the time spent on file transfers and backups. -
Versatile compatibility
The inclusion of both USB-C and USB-C to USB-A cables provides flexible connection options, allowing the drive to be easily used with a wide range of devices, from modern laptops to legacy systems.
- LaCie Porsche Design Desktop Drive STFE6000401 - hard drive - 6 TB - USB 3.1
- Hard drive - external (desktop)
- Capacity
- 6 TB
- Interface
- USB 3.1
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Power Source
- Included AC adapter
- 123 mm x 178 mm x 39 mm
- 870 g
- Localisation
- Canada, United States
- 2-year warranty
- Capacity
- 6 TB
- Interface
- USB 3.1
- 123 mm
- 178 mm
- 39 mm
- 870 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.1
- Power Source
- Power Device
- Power adapter
- Software Included
- LaCie Backup Assistant, LaCie Private-Public, Eco mode
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows 7 or later
- Cables Included
- 1 x USB-C cable - external , 1 x USB-C to USB-A cable - external
- Localisation
- Limited warranty - 2 years
