With the LaCie Porsche Design Desktop Drive, LaCie offers a hard drive that's as powerful as it is beautiful. The LaCie Desktop Drive features a USB 3.0 interface for fast speeds plus a solid, aluminum casing that looks great.
- LaCie Porsche Design Desktop Drive STEW6000400 - hard drive - 6 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 6 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Apple Time Machine compatible
- Power Source
- Included AC adapter
- 120.5 mm x 190.5 mm x 41 mm
- 1.1 kg
- Localisation
- Worldwide
- 2-year warranty
- Capacity
- 6 TB
- Interface
- USB 3.0
- 120.5 mm
- 190.5 mm
- 41 mm
- 1.1 kg
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Power Device
- Power adapter
- Software Included
- LaCie Backup Assistant, Eco mode
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows 7 or later
- Cables Included
- 1 x USB 3.0 cable - external
- Enclosure Material
- Aluminium
- Localisation
- Worldwide
- Limited warranty - 2 years
