LaCie 6TB d2 Thunderbolt 3 & USB 3.1 7200 External HD
Quicklinx: DCM1WS00 Mfr#: STFY6000400
The perfect complement to SSD-based laptops and all-in-one computers, the d2 Thunderbolt 3 massively expands your capacity for professional bandwidth-intensive creative applications. With Thunderbolt 3 and USB 3.1 speeds through the USB-C port, the LaCie d2 performs perfectly on late model laptops - as well as on USB 3.0-compatible computers.
  • Power and versatility
    From a single, mighty port, you get astonishing bandwidth with the versatility of the USB-C industry standard. For the LaCie d2 Thunderbolt 3, the result is high performance for cutting-edge creative workflows, wide compatibility, and time-saving device configurations.
  • Daisy chaining
    Thanks to dual Thunderbolt 3 ports, you can daisy chain seevral displays - all through a single cable connected to your computer.
  • Solid components, solid investment
    Forged from a single sheet of aluminum, the enclosure provides uncommon rigidity for long-term durability. The whisper-quiet fan and heat-dissipating aluminum enclosure pull heat away from the HDD, keeping it running fast and healthy.
LaCie d2 Thunderbolt 3 - hard drive - 6 TB - USB 3.1 Gen 1 / Thunderbolt 3
Hard drive - external (desktop) - Enterprise
6 TB
USB 3.1 Gen 1 / Thunderbolt 3 - USB-C
Data Transfer Rate
40 Gbps (Thunderbolt 3) / 5 Gbps (USB 3.0)
Enterprise
Power Source
Included AC adapter
217 mm x 130 mm x 60 mm
2.2 kg
Worldwide
5-year warranty
6 TB
Enterprise
217 mm
130 mm
60 mm
2.2 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
240 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C , 2 x Thunderbolt 3 - 24 pin USB-C
Power Source
Included AC adapter
Power adapter
Windows 8 or later, Apple macOS Sierra 10.12 or later
1 x USB-C to USB-A cable - external , 1 x Thunderbolt cable - external
Enclosure Material
Aluminium
Worldwide
Limited warranty - 5 years
