Product
LaCie 6TB d2 Thunderbolt 2 & USB 3.0 7200 External HD
Quicklinx: DCLZWS00 Mfr#: STEX6000400
Form Factor: 3.5"
Capacity: 6TB
Interface: USB 3.0
29 in stock
£249.89 ex VAT
£299.86 inc VAT
Get the job done faster - on any computer - with dual Thunderbolt 2 and USB 3.0. Thanks to its innovative, all-aluminum unibody design, you'll notice incredibly low vibration and operating noise.
  • Versatility for professional environments
    The LaCie d2 combines Thunderbolt 2 and USB 3.0 interfaces to deliver fast speeds when connected to any PC or Mac computer.
  • Innovative design
    When recreating the industrial design of the d2, LaCie focused relentlessly on reliability and usability for professionals.
  • Unibody enclosure
    The casing is forged from a single sheet of aluminum, providing uncommon rigidity for long-term durability and premium quality.
LaCie d2 Thunderbolt 2 - hard drive - 6 TB - USB 3.0 / Thunderbolt 2
Hard drive - external (desktop)
6 TB
Data Transfer Rate
20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Power Source
Included AC adapter
217 mm x 130 mm x 60 mm
1.7 kg
Worldwide
3 years warranty
6 TB
217 mm
130 mm
60 mm
1.7 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
180 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 , 2 x Thunderbolt 2
Power Source
Included AC adapter
Power adapter
Microsoft Windows 7 / Windows 8, Apple MacOS X 10.8.5 or later
1 x Thunderbolt cable , 1 x USB 3.0 cable
Worldwide
Limited warranty - 3 years
Form Factor: 3.5"
Capacity: 6TB
Interface: USB 3.0
Brand: LaCie
Price Range Ex VAT: 150 - 300
