LaCie 6TB d2 Quadra FireWire + USB 3.0 Desktop
Quicklinx: DDY4WS00 Mfr#: STGJ6000400
Form Factor: 3.5"
Capacity: 6TB
£220.88 ex VAT
£265.05 inc VAT
With the USB 3.0 interface and huge capacity, the LaCie d2 Quadra desktop drive is the ideal tool for creative professionals who need both fast speeds and large storage capacity. It can handle resource-intensive applications. The d2 Quadra has advanced connectivity with USB 3.0 and FireWire 800 interfaces for daisy chaining, but it is still fully compatible with eSATA, USB 2.0 and FireWire 400. With all of its interfaces, the d2 Quadra has universal connectivity, so it's easy to back up and restore any workstation, no matter the configuration and interfaces. And thanks to the USB 3.0 performance, you can make faster, more frequent backups of your data, keeping it safe and secure.
  • Performance and reliability
  • Cross-platform applications
LaCie d2 Quadra - hard drive - 6 TB - FireWire 800 / USB 3.0 / eSATA-300
Hard drive - external (desktop)
6 TB
Data Transfer Rate
800Mbps(FireWire800)/5Gbps(USB 3.0)/3Gbps(eSATA)
Spindle Speed
7200 rpm
Power Source
Included AC adapter
4.4 cm x 15.9 cm x 17.2 cm
2.3 kg
Worldwide
3-year warranty
6 TB
4.4 cm
15.9 cm
17.2 cm
2.3 kg
Performance
Interface Transfer Rate
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x eSATA-300 , 2 x FireWire 800 , 1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Windows 8 or later, Apple MacOS X 10.12 or later
Vertical stand
1 x IEEE 1394b cable - external , 1 x USB 3.0 cable - external , 1 x eSATA cable - external
Worldwide
Limited warranty - 3 years
Form Factor: 3.5"
Capacity: 6TB
Brand: LaCie
Price Range Ex VAT: 150 - 300
