This quadruple interface professional 2-disk RAID delivers fast speed, large capacity and data security. With eSATA 3Gbits, FireWire 800, FireWire 400 and Hi-Speed USB 2.0, it provides complete universal compatibility with any PC or Mac. The easy-to-use 2big Quadra comes with two extractable, lockable and hot-swappable disks for a user-controlled solution. With four RAID levels, it meets your storage needs, whether it's security, capacity, speed or a combination. With burst transfer rates as high as 165MB/s (eSATA), it's ideal for audio/video projects. The sturdy heat sink metal design provides 60% more surface area for natural heat dissipation.
- LaCie 2big Quadra - hard drive array
- Hard drive array
- Total Array Capacity
- 6 TB
- Interface
- FireWire 800, USB 3.0
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Storage Controller
- RAID RAID RAID 0, 1
- Storage Controller Quantity
- 1
- Hard Drive
- 2 x 3 TB
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
- Power
- 50/60 Hz
- 9.1 cm x 17.2 cm x 20 cm
- 3.6 kg
- 3-year warranty
- Hard drive array
Chassis
- 2
- Supported Devices / Modules Qty
- 2
Storage
- 6 TB
- HDD Array External Interface
Storage Controller
- RAID - integrated
- Installed Qty
- 1
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1
Storage Controller (2nd)
- Installed Qty
- 1
Hard Drive
- Plug-in module
- Capacity
- 2 x 3 TB
- Spindle Speed
- 7200 rpm
- 2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0
- OS Required
- Cables Included
- 1 x USB 3.0 cable , 1 x IEEE 1394b cable
- Software Included
- Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Desktop Manager
- Included Accessories
- Stand
- Power Device
- External power adapter
- Voltage Required
- 50/60 Hz
- 9.1 cm
- 17.2 cm
- 20 cm
- 3.6 kg
- Limited warranty - 3 years
