LaCie 5big Thunderbolt 2 40TB RAID 5/6
Quicklinx: DDXXWS00 Mfr#: STFC40000400
Type: Hard drive array
Controller Type: RAID
£2,160.94 ex VAT
£2,593.12 inc VAT
For 4K and other bandwidth-hungry workflows, external storage needs to be fast, secure, reliable, and quiet. The LaCie 5big fits the bill, delivering Thunderbolt 2 speeds for 4K video editing, large capacity, and hardware RAID for no-compromise data security.
  • Thunderbolt 2 Speeds for the 4K Era
    With Thunderbolt 2 technology, the interface is no longer the performance bottleneck. For the 5big, LaCie harnessed the breakthrough performance potential of the Thunderbolt 2 I/O, squeezing the absolute best speeds out of the hard disks. Add a hardware RAID controller and disks and the result is incredible, sustained high speeds, that turbocharge 4K workflows, file transfers, and backups.
  • 5big-THB2-Speed-B-Content-Row
    With this kind of speed, videographers can work directly from RAW files in Apple Final Cut Pro or Adobe Premiere, get maximum quality from footage, and see edits in real time. No need to first convert footage into a lower resolution. Avid Pro Tools users will notice incredibly smooth audio mixing, even when working with hundreds of tracks simultaneously. Professional photographers using Adobe Lightroom or Apple Aperture can browse through archived libraries of thousands of RAW and edited images with zero lag.
  • RAID for Speed with Security
    The LaCie 5big offers RAID and JBOD. Its hardware RAID controller delivers sustained performance, better flexibility, and the ability to connect the product to another computer while keeping the RAID configuration. Preconfigured in HFS+ and RAID 5, it is truly plug and play for Mac users. And easily customize the RAID mode to suit your needs using the LaCie RAID Manager utility.
LaCie 5big Thunderbolt 2 - hard drive array
Hard drive array
Total Array Capacity
40 TB
Thunderbolt 2
5 (installed) / 5 (max)
Supported Drives
SATA-600
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
5 x 8 TB HDD - hot-swap - Enterprise
Microsoft Windows 7 / Windows 8, Apple MacOS X 10.9 or later
AC 120/230 V - 50/60 Hz
17.3 cm x 19.6 cm x 22 cm
7.6 kg
3-year warranty
Hard drive array
Chassis
5
Supported Devices / Modules Qty
5
Supported Drives
SATA-600
Storage
40 TB
HDD Array External Interface
Thunderbolt 2
Storage Controller
RAID
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
5 x 8 TB
Spindle Speed
7200 rpm
Enterprise
Expansion Bays
5 (total) / 0 (free) x hot-swap - 3.5"
2 x Thunderbolt
Security lock slot (cable lock sold separately), aluminum enclosure, built-in cooling fan, software encryption
1 x Thunderbolt cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
AES-256
External power adapter
Power Provided
150 Watt
17.3 cm
19.6 cm
22 cm
7.6 kg
Limited warranty - 3 years
Brand: LaCie
Price Range Ex VAT: 1500+
