Your basket is empty
LaCie 500GB Rugged USB 3.0 & FireWire 800 7200RPM Hard Drive
Quicklinx: 80VQWS00 Mfr#: LAC301983
Form Factor: 2.5"
Capacity: 500GB
Interface: SuperSpeed USB
Stock Status: Clearance
Hurry, only 1 left in stock!
£71.87 ex VAT
£86.24 inc VAT
The LaCie Rugged Triple hard disk provides universal connectivity: you've got the superior speeds of USB 3.0. Additionally, you can use the LaCie Mac USB 3.0 driver to improve data transfer speed on your Mac. Whether your goal is super speed or complete compatibility, the Rugged Triple has everything you need.
It conforms to military standard 810-F, and can support drops from up to two meters. It helps you carry your files with confidence, no matter where the road takes you, thanks to its shock-absorbing sleeve, aluminum anti-scratch casing, internal rubber bumpers, and a 1000 G shock-resistant hard drive. Calculations are based on average read time.
LaCie AES 256-bit encryption software comes standard with the Rugged Triple. AES 256-bit encryption technology is one of the most robust on the market today, and makes the Rugged Triple more secure than ever. With LaCie Private-Public software built-in, it's easy to make sure that your files are secure and protected, no matter where you go. Automatic eco mode lowers the power consumption by up to 40% when not in use, increasing the battery life of your notebook or laptop.
LaCie Rugged Triple - hard drive - 500 GB - FireWire 800 / USB 3.0
Hard drive - external (portable)
500 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
Data Transfer Rate
800Mbps(FireWire800)/5Gbps(USB 3.0)
Spindle Speed
7200 rpm
Shock resistant, hardware encryption, rugged, automatic backup, 256-bit AES
9 cm x 14.5 cm x 2.8 cm
260 g
3 years warranty
500 GB
Hardware Encryption
256-bit AES
9 cm
14.5 cm
2.8 cm
260 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
110 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0
Software Included
LaCie Setup Assistant, LaCie Backup Assistant
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
1 x USB 3.0 cable - external , 1 x IEEE 1394b cable - FireWire 800 (9-to-9 pin) - external
MIL-STD 810F
3 years warranty
Limited warranty - 3 years
Form Factor: 2.5"
Capacity: 500GB
Brand: LaCie
Price Range Ex VAT: 50 - 100
