Your basket is empty
LaCie 500GB Rugged Mini USB 3.0 7200RPM 2.5" Portable Hard Drive
Quicklinx: 7LF4WS00 Mfr#: LAC301556
Form Factor: 2.5"
Capacity: 500GB
Interface: SuperSpeed USB
More than 50 in stock
£53.30 ex VAT
£63.96 inc VAT
Standard delivery Delivered within 3-5 working days
The best protection of your data requires handling with care, but you and your data don't always live in a peaceful, sterile vacuum. You live in the real world full of bumps, spills and adventures. The ultra-portable LaCie Rugged Hard Disk is your data's best protection for the real world. Its unique varnished, scratch-protected aluminum shell and shock-resistant rubber sleeve make the LaCie Rugged Hard Disk especially resistant to harsh elements for extra protection wherever you go.
  • Capacity: 500GB
  • Fastest interface on the market: speeds up to 110MB/s
  • Includes bus powered cable for convenience and mobility
  • Rugged design: drop resistant up to 2.2 meters
  • Computer with a USB 3.0 or USB 2.0 port
  • High-speed internet for online storage
  • Latest version of Windows® XP, Windows Vista®, Windows 7 / Mac® OS X 10.5, 10.6 (in USB 2.0 only)
  • Minimum free disk space: 600 MB recommended
LaCie Rugged Mini - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Shock resistant, pressure-proof, rugged, rain-resistant
Power Source
USB bus
8.6 cm x 13.5 cm x 1.9 cm
240 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
500 GB
USB 3.0
8.6 cm
13.5 cm
1.9 cm
240 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
LaCie Backup Assistant
Apple MacOS X 10.6, Microsoft Windows 2000/XP/Vista/7, Apple MacOS X 10.5
1 x USB cable - external
Form Factor: 2.5"
Capacity: 500GB
Brand: LaCie
Price Range Ex VAT: 50 - 100
