With the P'9233's USB 3.0 interface, you'll be able to get the job done faster than ever before. Speeds up to 5Gb/s allow you to transfer a 700 MB video file in just under 7 seconds. Back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the P'9233, the possibilities are endless.
- LaCie Porsche Design P'9233 - hard drive - 4 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 4 TB
- Interface
- USB 3.0
- Automatic backup, Apple Time Machine compatible
- Power Source
- Included AC adapter
- 120 mm x 190 mm x 38 mm
- 1 kg
- 2 years warranty
- Capacity
- 4 TB
- Interface
- USB 3.0
- 120 mm
- 190 mm
- 38 mm
- 1 kg
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Software Included
- LaCie Backup Assistant, LaCie Private-Public, LaCie Desktop Manager Eco Mode, Wuala
- OS Required
- Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB 3.0 cable
- Limited warranty - 2 years
