LaCie 4TB Porsche Design 3.5" USB 3.0 Space Grey Desktop Hard Drive
Quicklinx: DDVJWS00 Mfr#: STEW4000400
The LaCie desktop drive features a USB 3.0 interface for fast speeds plus a solid, aluminum casing that looks great.
LaCie Porsche Design - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop) - Apple Time Machine compatible
4 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Power Source
Included AC adapter
41 mm x 190.5 mm x 120.5 mm
1.1 kg
Worldwide
4 TB
USB 3.0
41 mm
190.5 mm
120.5 mm
1.1 kg
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Microsoft Windows 7, Apple MacOS X 10.5 or later, Windows 8
1 x USB 3.0 cable - external
Enclosure Material
Aluminium
Worldwide
