Product
LaCie 4TB d2 Quadra USB 3.0 eSATA 3Gb/s & FireWire 800 [7200]
Quicklinx: 9BVZWS00 Mfr#: LAC9000258EK
Form Factor: 3.5"
Capacity: 4TB
Interface: SuperSpeed USB
£147.04 ex VAT
£176.44 inc VAT
With the USB 3.0 5 Gb/s interface, the LaCie d2 Quadra hard disk is the ideal tool for creative professionals who need both fast speeds and large storage capacity. It features 7200 rpm drives with a minimum of 32 MB cache for the best performance and seek times, so it can handle the most resource-intensive applications. Best of all, it can achieve speeds up to 130 MB/s in USB 3.0.
  • The professional choice for performance and reliability
  • The professional choice for cross-platform applications
    The d2 Quadra has got the connectivity with USB 3.0 and two FireWire 800 interfaces for daisy chaining, but it is still fully compatible with, eSATA 3 Gb/s, USB 2.0 and FireWire 400. It's even USB 3.0-compatible on Mac computers, thanks to LaCie's USB 3.0 driver for Mac OS. With all of its interfaces, the d2 Quadra has universal connectivity, so it is easy to back up and restore any workstation, no matter the configuration and interfaces. And thanks to the USB 3.0 performance, you can make faster, more frequent backups of your data, keeping it safe and secure. Since the d2 Quadra tops out a high capacity, it can even be used as a simple and convenient storage expansion for a server.
  • The professional choice for functional and user-centric features
    With the preloaded LaCie desktop manager, you can easily configure the shortcut button to launch the application of your choice in one push and configure your drive's eco mode. And, with its two-color front LED indicator, it is easy to check the drive status. It also includes Genie Backup Assistant software and Intego Backup Assistant software with data restore for Windows and Mac. Both products provide an ideal solution for a simple and user-friendly backup and file retrieval.
  • The professional choice for design
    The d2 Quadra's unique and unobtrusive design is respected in the creative content industry for good reason. The unique, fanless aluminum heat sink design provides an increased surface area, keeping it quiet, safe, and free from dust inside. It can also stand upright, be stacked horizontally with other drives, or even be rackmounted to save desktop space. It's a superb solution for heavy storage users who want off-site backups and archives of any work environment. For superior energy efficiency, it also has a programmable eco mode, which automatically conserves energy if the drive is inactive for a certain period of time. On top of that, it's recyclable and RoHS-compliant.
LaCie d2 Quadra USB 3.0 - hard drive - 4 TB - FireWire 800 / USB 3.0 / eSATA-300
Hard drive - external (desktop)
4 TB
Spindle Speed
7200 rpm
Power Source
Included AC adapter
60 mm x 168 mm x 183 mm
1.7 kg
Microsoft Certification
Compatible with Windows 7
3 years warranty
4 TB
60 mm
168 mm
183 mm
1.7 kg
Performance
Data Transfer Rate Details
Serial ATA: 115 MB/s , FireWire 800: 85 MB/s , USB 3.0: 130 MB/s , USB 2.0: 35 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x eSATA-300 , 2 x FireWire 800 , 1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
LaCie Setup Assistant, LaCie Desktop Manager, LaCie Backup Assistant
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 or later, Apple MacOS X 10.5
Vertical stand
1 x eSATA cable - external , 1 x IEEE 1394b cable - FireWire 800 (9-to-9 pin) - external , 1 x USB 3.0 cable - external
Limited warranty - 3 years
Form Factor: 3.5"
Capacity: 4TB
Brand: LaCie
Price Range Ex VAT: 100 - 150
