Your basket is empty
LaCie 4TB d2 Quadra USB 3.0 eSATA 3Gb/s & FireWire 800 [7200]
Quicklinx: 9BVZWS00 Mfr#: LAC9000258EK
With the USB 3.0 5 Gb/s interface, the LaCie d2 Quadra hard disk is the ideal tool for creative professionals who need both fast speeds and large storage capacity. It features 7200 rpm drives with a minimum of 32 MB cache for the best performance and seek times, so it can handle the most resource-intensive applications. Best of all, it can achieve speeds up to 130 MB/s in USB 3.0.
LaCie d2 Quadra USB 3.0 - hard drive - 4 TB - FireWire 800 / USB 3.0 / eSATA-300
Hard drive - external (desktop)
4 TB
Spindle Speed
7200 rpm
Power Source
Included AC adapter
60 mm x 168 mm x 183 mm
1.7 kg
Microsoft Certification
Compatible with Windows 7
3 years warranty
4 TB
60 mm
168 mm
183 mm
1.7 kg
Performance
Data Transfer Rate Details
Serial ATA: 115 MB/s , FireWire 800: 85 MB/s , USB 3.0: 130 MB/s , USB 2.0: 35 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x eSATA-300 , 2 x FireWire 800 , 1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
LaCie Setup Assistant, LaCie Desktop Manager, LaCie Backup Assistant
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 or later, Apple MacOS X 10.5
Vertical stand
1 x eSATA cable - external , 1 x IEEE 1394b cable - FireWire 800 (9-to-9 pin) - external , 1 x USB 3.0 cable - external
3 years warranty
Limited warranty - 3 years
