Product
LaCie 48TB 8big 8-bay 1U Rackmount Dual Thunderbolt 2
Quicklinx: 9M11WS00 Mfr#: LAC9000476EK
Fiber Channel DAS has been dethroned. Featuring Thunderbolt 2 speeds of up to 1330MB/s and 48TB in a 1U rackmount size, the LaCie 8big Rack has seized the crown. Video pros, meet the king of storage for 4K workflows.
  • Bulletproof reliability
    With full component redundancy, the LaCie 8big Rack gives professionals superb reliability and data security. Fans, disks, and PSU are fully redundant, hot swappable, and user-serviceable. And hardware RAID 5/6 provides security against disk failure and data loss, without compromising on transfer speeds. Whatever the contingency, zero data loss, and zero downtime. Its innovative cooling system prolongs component lifespan, featuring three efficient, thermoregulated cooling fans to drive airflow. A metal sheet beneath the disks dissipates heat, and cool air flows under the sheet to drain hot air away. Above and between the two rows of disks, air flows from front to back, conducting heat away from sensitive components.
  • Most powerful I/O, reinvented
    Thunderbolt technology redefined external storage with its speed and versatility for bandwidth-intensive applications. Thunderbolt 2 builds on those advances by doubling the speed potential to 20Gb/s and enabling simultaneous RAW 4K video editing and display. And thanks to support for DisplayPort 1.2, it's now possible to daisy chain higher-resolution displays such as 4K monitors. In addition to higher performances, the Thunderbolt 2 I/O offers dramatically simpler connections than Fiber Channel. Connect the LaCie 8big Rack to a computer via the Thunderbolt cable - no HBA (host bus adapter) necessary - and instantly the volume mounts on your OS.
  • Innovative design, breakthrough usability
    The LaCie 8big Rack industrial design demolishes the status quo for rack storage, with a relentless focus on usability for professionals.
LaCie 8big Rack Thunderbolt 2 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 1U
Total Array Capacity
48 TB
Thunderbolt 2
8 (installed) / 8 (max)
Supported Drives
SATA-600
Built-in Devices
Led panel
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 6 TB HDD - hot-swap
Apple MacOS X 10.9 or later
AC 120/230 V - 50/60 Hz
Power Redundancy
47.7 cm x 77.2 cm x 4.4 cm
20 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 1U
Chassis
Built-in Devices
Led panel
8
Supported Devices / Modules Qty
8
Supported Drives
SATA-600
Storage
48 TB
HDD Array External Interface
Thunderbolt 2
Storage Controller
RAID
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
8 x 6 TB
Spindle Speed
7200 rpm
Expansion Bays
8 (total) / 0 (free) x hot-swap - 3.5"
2 x Thunderbolt
Redundant fans, aluminum enclosure, hot-swappable fans
1 x Thunderbolt cable
Software Included
Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
AES-256
Max Supported Qty
2
Power Redundancy
Power Provided
250 Watt
47.7 cm
77.2 cm
4.4 cm
20 kg
Limited warranty - 3 years
5 °C
10 - 60% (non-condensing)
Sound Emission
50 dB
