Fully loaded with all the best interfaces - eSATA 3Gbits, FireWire 800, FireWire 400 and USB 2.0 - this all-in-one professional hard disk offers universal connectivity for PC and Mac users. For easy setup, the LaCie Setup Assistant helps format according to your needs. The unique, fanless aluminum heat sink design with 60 % more surface area for heat dissipation keeps it quiet and safe. With the LaCie Shortcut Button, easily launch any application in one push. Perfect for digital content creation, audio / video editing, DVD authoring, and web animation, etc., the d2 Quadra can handle multiple demanding professional tasks. It can be daisy-chained via FireWire or connected to your DV camera and is even bootable in FireWire for Mac and in eSATA for Mac / PC.
- LaCie d2 Quadra Hard Disk - hard drive - 3 TB - FireWire 800 / USB 3.0 / eSATA-300
- Hard drive - external (desktop)
- Capacity
- 3 TB
- Interface
- Data Transfer Rate
- 800Mbps(FireWire800)/5Gbps(USB 3.0)/3Gbps(eSATA)
- Spindle Speed
- 7200 rpm
- Power Source
- Included AC adapter
- 18.3 cm x 16.8 cm x 6 cm
- 1.7 kg
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 3 TB
- Interface
- 18.3 cm
- 16.8 cm
- 6 cm
- 1.7 kg
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 130 MB/s
- Data Transfer Rate Details
- USB 3.0: 130 MB/s , Serial ATA: 115 MB/s , FireWire 800: 85 MB/s
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x eSATA-300 - 7 pin external Serial ATA , 2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0 - 9 pin USB Type B
- Power Source
- Power Device
- Power adapter
- Software Included
- LaCie Setup Assistant, LaCie Desktop Manager, LaCie Backup Assistant
- OS Required
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 or later, Apple MacOS X 10.5
- Included Accessories
- Vertical stand
- Cables Included
- 1 x USB 3.0 cable - USB Type A to B - external , 1 x eSATA cable - external , 1 x IEEE 1394 cable - FireWire 800 (9-to-9 pin) - external
- Limited warranty - 3 years
