Your basket is empty
LaCie 2TB Rugged Triple FW800 & USB 3.0 2.5" Portable Drive
Quicklinx: 9BVVWS00 Mfr#: LAC9000448
Form Factor: 2.5"
Capacity: 2TB
Interface: SuperSpeed USB
£124.12 ex VAT
£148.94 inc VAT
The LaCie Rugged Triple hard disk provides universal connectivity: you've got the superior speeds of USB 3.0. Additionally, you can use the LaCie Mac USB 3.0 driver to improve data transfer speed on your Mac. Whether your goal is super speed or complete compatibility, the Rugged Triple has everything you need.
It conforms to military standard 810-F, and can support drops from up to two meters. It helps you carry your files with confidence, no matter where the road takes you, thanks to its shock-absorbing sleeve, aluminum anti-scratch casing, internal rubber bumpers, and a 1000 G shock-resistant hard drive. Calculations are based on average read time.
LaCie AES 256-bit encryption software comes standard with the Rugged Triple. AES 256-bit encryption technology is one of the most robust on the market today, and makes the Rugged Triple more secure than ever. With LaCie Private-Public software built-in, it's easy to make sure that your files are secure and protected, no matter where you go. Automatic eco mode lowers the power consumption by up to 40% when not in use, increasing the battery life of your notebook or laptop.
LaCie Rugged Triple - hard drive - 2 TB - FireWire 800 / USB 3.0
Hard drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
Data Transfer Rate
800Mbps(FireWire800)/5Gbps(USB 3.0)
Shock resistant, hardware encryption, rugged, automatic backup, 256-bit AES
90 mm x 145 mm x 28 mm
260 g
2 years warranty
2 TB
Hardware Encryption
256-bit AES
90 mm
145 mm
28 mm
260 g
Performance
Interface Transfer Rate
Expansion & Connectivity
2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0
Software Included
LaCie Setup Assistant, LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
1 x USB 3.0 cable - external , 1 x IEEE 1394b cable - external
MIL-STD 810F
Form Factor: 2.5"
Capacity: 2TB
Brand: LaCie
Price Range Ex VAT: 100 - 150
