LaCie 2TB Rugged Thunderbolt USB-C + USB 3.0
Quicklinx: DDVSWS00 Mfr#: STFS2000800
Legendary Rugged toughness meets USB-C compatibility, blazing-fast Thunderbolt speeds. Also featuring a tethered cable and IP54-rated resistance to the elements, this Rugged drive means you don't have to compromise between durability, mobility, and speed.
LaCie Rugged Thunderbolt USB-C - hard drive - 2 TB - USB 3.1 Gen 1 / Thunderbolt
Hard drive - external (portable)
2 TB
USB 3.1 Gen 1 / Thunderbolt - USB-C
Shock resistant, water resistant, dust-proof, crush-resistant
Power Source
USB bus
8.98 cm x 14.01 cm x 2.5 cm
400 g
Worldwide
3-year warranty
2 TB
8.98 cm
14.01 cm
2.5 cm
400 g
Performance
Max Data Transfer Rate
130 MB/s
Expansion & Connectivity
1 x Thunderbolt - 24 pin USB-C
Power Source
USB bus
Apple MacOS X 10.5 or later, Microsoft Windows 7 or later
Protective cover
1 x USB-C cable
IP54
Worldwide
Limited warranty - 3 years
