Legendary Rugged toughness meets USB-C compatibility, blazing-fast Thunderbolt speeds. Also featuring a tethered cable and IP54-rated resistance to the elements, this Rugged drive means you don't have to compromise between durability, mobility, and speed.
- LaCie Rugged Thunderbolt USB-C - hard drive - 2 TB - USB 3.1 Gen 1 / Thunderbolt
- Hard drive - external (portable) - shock resistant, water resistant, dust-proof, crush-resistant
- Capacity
- 2 TB
- Interface
- USB 3.1 Gen 1 / Thunderbolt - USB-C
- Shock resistant, water resistant, dust-proof, crush-resistant
- Power Source
- USB bus
- 8.98 cm x 14.01 cm x 2.5 cm
- 400 g
- Localisation
- Worldwide
- 3-year warranty
- Capacity
- 2 TB
- Interface
- 8.98 cm
- 14.01 cm
- 2.5 cm
- 400 g
Performance
- Max Data Transfer Rate
- 130 MB/s
Expansion & Connectivity
- 1 x Thunderbolt - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows 7 or later
- Included Accessories
- Protective cover
- Cables Included
- 1 x USB-C cable
- IP54
- Localisation
- Worldwide
- Limited warranty - 3 years
