LaCie 2TB Porsche Design 2.5" USB 3.0 Portable Hard Drive - Grey
Quicklinx: DDV9WS00 Mfr#: STET2000400
With the LaCie Porsche Design Mobile Drive's USB 3.0 interface, you'll be able to transfer files faster than ever before. Back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With speeds up to 100 MB/s, the possibilities are endless.
  • Accelerate your backup with USB 3.0
  • Porsche design form, LaCie function
    With the LaCie Mobile Drive, an exclusive and timeless shape was produced, with solid, reliable hardware that's sure to last for years. You can use it anywhere and be confident that you're getting superb performance.
  • Safe, strong, and aluminum
    With 3 mm of solid aluminum casing surrounding the disk inside, the LaCie Mobile Drive keeps your data solidly protected. LaCie and Porsche Design worked together to combine form and function-resulting in a drive that looks great (and works great!) no matter where you take it.
  • Designed for your Mac
    The LaCie Mobile Drive was designed especially for Mac computers, and features a stylish, sophisticated aluminum finish that matches your MacBook. Plus, it's Time Machine compatible so that you can seamlessly backup to the drive using Mac's built-in software.
LaCie Porsche Design Mobile Drive for Mac STET2000400 - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
77 mm x 130 mm x 15 mm
240 g
2 TB
USB 3.0
77 mm
130 mm
15 mm
240 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Software Included
Economy Mode (ECO) Setting Utility, LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.5 or later, Microsoft Windows 7 / 8 / 10
1 x USB 3.0 cable - external
Enclosure Material
Aluminium
