The LaCinema Classic HD provides uncompromising quality, adding stunning 1080p playback through HDMI on your HDTV. No matter the video, music or photo format and resolution, the LaCinema Classic HD will play it seamlessly with the highest sound and image quality. It's compatible with all the most popular video formats on the market, from DivX, MKV, to AVC and H.264, and provides uncompromised Dolby Digital quality sound.
It's easy to play your movie library on your HDTV: connect the LaCinema Classic HD to your computer to store your movies then connect it to your TV for instant playback. No configuration is required.
UPnP /DLNA capabilities also ensure that the LaCinema Classic HD works in tandem with your home network, connecting easily to your PC or network storage (like a LaCie Network Space) so it's simple to populate with your media. In a snap, you can play all of your media - no matter where it's stored.
The LaCinema Classic HD can also be turned into a powerful media server that will allow you to use it as a central location for all of your media. You can even share content with a Playstation or Xbox, with the LaCinema Classic HD functioning as your primary media player.
You can store your entire digital media library in one location. This user-friendly media player is quiet and fanless, and adds sophisticated style to your home. A user-friendly navigation and remote control have been made to enhance your entertainment experience. You can even quickly connect a USB storage key to the front of your LaCinema Classic HD to instantly watch movies on your TV.
Connect Your PC and HDTV
Play your movie library on your HDTV in two easy steps: connect the LaCinema Classic HD to your computer to easily store your movies then connect it to your TV for instant playback. No configuration is required. You'll save time and avoid having to burn CDs/DVDs to hold all of your media. You'll also be able to store and enjoy your MKV, DivX, and many more file types on any TV. -
Made for HDTV
Improve the look of your movies and photos on your HDTV with full HD 1080p playback and upscaling. With no compromise on quality, the LaCinema Classic HD goes one step further by adding stunning 1080p playback through HDMI. This multimedia hard disk supports a wide variety of video, photo, and music formats. -
Easy to Use
You can store your entire digital media library in one location this user-friendly drive, made by Neil Poulton, adds sophisticated style to your home and it's fanless for silent operation. An easy-to-use on-screen menu and remote control have been made to improve your experience. A front USB port allows you to quickly connect a USB storage key to instantly watch movies on your TV. -
Media Player and Server Hard Disk
DLNA and UPnP capabilities ensure that the LaCinema Classic HD works in tandem with your home network, connecting easily to your PC or NAS, so it's easy to populate with your media. After that, it's simple to connect it to your HDTV, making viewing your movies and media in HD easy. Since it has the widely-used USB 2.0 interface, you can plug it into just about any PC or Mac for an easy, quick storage solution.
- LaCie LaCinema Classic HD - digital multimedia receiver / HDD recorder
- Product Type
- Digital multimedia receiver / HDD recorder
- Internal Storage
- Hard disc drive - 2 TB
- Audio
- Stereo
- Remote Control
- Remote control
- Product Type
System
- Progressive scanning (line doubling), upgradable firmware
Audio System
- Output Mode
- Stereo
- Digital Audio Format
- Dolby Digital output, DTS digital output
Connectors
- Optical Digital Output
Digital Player (Recorder)
- Internal Storage
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback
- Connectivity
- Wired
- Connectivity Protocols
- IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet)
- Network Protocols Supported
- DHCP, IP
- Supported Audio Formats
- MP3, WMA, WAV, PCM, AC3, AAC, Ogg Vorbis, FLAC (Free Lossless Audio Codec)
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Xvid, DivX, WMV, ASF, AVI, MKV, MOV, VOB, DivX HD, TS, H.264
- Supported Pictures Formats
- BMP, JPG, GIF, TIFF, PNG
Supported Video Resolutions
- Supported Video Resolutions
- 1920 x 1080
System Requirements Details
- System Requirements Details
- Windows XP/Vista/7 , MacOS X 10.4 , MacOS X 10.5
Remote Control
- Remote control
- Connector Type
- USB - rear , HDMI output (19 pin HDMI Type A) - rear , Composite video/audio output (RCA x 3) - rear , USB (4 PIN USB Type A) - rear , USB (4 PIN USB Type A) - side , SPDIF output (TOS Link) - rear , LAN (RJ-45) - rear
- Included Accessories
- Remote control, video / audio cable, USB cable, HDMI cable, power adapter
- External
Dimensions & Weight Details
- Dimensions (WxDxH) / Weight
- 11.7 cm x 19.3 cm x 4.5 cm / 950 g
